05-19-2017, 11:42 AM | #1 |
FatMat in the doors
Last night I installed some FatMat in my doors. Seems to have made them quieter but they are definitely more solid now when closing.
Next over the holiday weekend ill pull the seat and carpet and do the floor and over the front of the gas tank. I notice the carpet only goes up so far, so I am thinking ill have to paint the aluminum on the FatMat a flat black where it is exposed. Was thinking under the kick panels too since I have kick panel speakers. Anyone have any tips or pointers with the installation areas? Thanks in advance.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-19-2017, 12:16 PM | #2 |
Active Member
Re: FatMat in the doors
The only that about installing matting is it can hole moisture and start rusting door in time
05-19-2017, 01:40 PM | #3 |
If you still have access to where you've put the fatmat in your doors, I'm going to offer you some sage advice. I used fatmat in my doors also -- the exact brand FatMat.
After 9 months to a year, the adhesive failed. I am pretty sure there was a good clean surface in the doors, as I had the bottoms of the doors cut off to replace rusted metal. I cleaned out the inside of the doors, painted them with Eastwood's rust encapsulator and later applied the fatmat. It may just be that fatmat won't stick to rust encapsulator, I don't know, but I had to go back and use a sealant to re-apply the fatmat inside the door. I haven't had any issues with the fatmat on the floor of the cab, just the vertical placement in the doors. I would recommend a good 3M adhesive applied to be sure the fatmat stays in place.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
05-19-2017, 10:06 PM | #4 |
I would recommend using CLD tiles. You only need 10% coverage and the stuff works well.
