Old 05-19-2017, 04:52 PM   #1
5spd540
On a 71 c10 step side
How much can you lower it without have major work and it be safe? I don't want to nag it. I was thinking 5-7 drop but don't know much about these trucks. This is my first full size truck.
5spd540 is offline   Reply With Quote
Old 05-19-2017, 07:19 PM   #2
PGSigns
PGSigns's Avatar
Re: On a 71 c10 step side
5/7 is a lot of drop to get started. What are the overall plans? Are you planning disc brakes or other mods? What wheel and tires are you thinking about? If you are thinking disc brakes 2 1/2 spindles and 2 inch springs. Then 4 to 6" springs depending on how much rake you want.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-19-2017, 08:15 PM   #3
5spd540
I have front disc and have not decided on wheels yet was thinking of 20x8 fronts and 20x10 or 12 on the rear
Old 05-20-2017, 07:39 AM   #4
zach_carver
zach_carver's Avatar
Most people I know like the 4/6 best. With spindles and springs in the front. 4/6 is a good drop, and still doesn't hang on everything.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-20-2017, 07:40 AM   #5
5spd540
I guess I need to see some pics of 4-6 and 5-7 drops so I can see how low it really is
Old 05-20-2017, 08:03 AM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=471442
30-odd pages of static drops there.
On a step side, good luck squeezing a 10" wide wheel with a 6 or 7 inch rear drop. 12" wide wheel is definitely not happening without a mini-tub, but that may already have been in your plans. Lots of info around here on lowered wheel and tire fitments, these questions are asked regularly. Using the search function will net you hours of material to read and pics to look at.
So, are you going to be running a '5 speed & 540' in this new truck? We need details!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-20-2017, 08:09 AM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
I will add that a big block up front and a 5" drop will require a pretty stiff spring to keep the crossmember/lower a-arms from kissing the concrete, as it will likely only be a few inches off the ground.
Adam
Old 05-20-2017, 08:10 AM   #8
5spd540
It's a step side truck and the bed is rotted to death so gonna tub it out and make it cool
Old 05-20-2017, 08:11 AM   #9
5spd540
It will be a small block the big block was in my 90 as truck I had
Old 05-20-2017, 08:37 AM   #10
5spd540
I will be running a 6spd and some type of small block around 400 to 450hp. Lowered 4-6 to 5-7 not bagged. 20 in wheels was thinking 20x8 and 20x 10 or 12 rear. It's a coil spring truck. Not dead set on any of it other than a small block and stick shift truck lowered. I am open to any ideas.
Old 05-20-2017, 09:25 AM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
I'm not on 20's, but my truck is lowered roughly 4.5" (spindles/springs) up front and 7.5" in back (6" spring, 1.5" block), but the big block adds a little more weight up front, so it's really closer to 5" (actual measurements, not guessing). I started out with a 2.5" spindle and 3" CPP drop spring, but I dragged the arms a couple times, so I went with stiffer Hotchkis 2" spring that's 1400#/inch and they keep everything high and tight .
What tire sizes are you wanting to run? My tires are 26.5" up front and 27" in the rear as they sit on the truck. Just something else to consider. Then you have to decide if you're going to run inner fenders, and then backspace of the wheels to make sure it all clears, and the list goes on...
Adam
Old 05-20-2017, 09:30 AM   #12
5spd540
I want the truck lowered and then I will build around that don't want to build around a set of wheels. Like I said before this is my first truck so I am new to all of this. I am open to ideas. I may. E going about this all wrong so if I am please steer me correct.
Old 05-20-2017, 09:31 AM   #13
5spd540
What size are your wheels . I love your set up.
Old 05-20-2017, 10:09 AM   #14
BossHogg69
motor exploder
BossHogg69's Avatar
19x9 in front, 6" backspace; 19x12 rear, 6" backspace. The rear end is narrowed 2" (it was already the narrower 67-70 six lug 12 bolt housing, and I cut 1" more off each side and swapped over to Ford 9" style housing ends)
Tires are 275/35 front, 345/30 rear. I'm running stock inner fenders. Nothing rubs, drags or scrapes.
Adam
Old 05-20-2017, 10:52 AM   #15
5spd540
I do think I would like to be able to use bought inner fenders and not have to build a set.
Old 05-20-2017, 01:55 PM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've driven 4/6 lowered trucks continuously since the late 80s. For me they just work. I haven't ever torn anything up that required repair.
I have owned a couple that were lower and you really need to be familiar with the roads or very diligent or you'll bash your front arms onto something. My current project is going down from 5/6 to 6/8 and I wouldn't want to drive it at night over unfamiliar roads unless I wasn't being rushed by heavy traffic and could pay real close attention to where I was going.
Old 05-20-2017, 02:45 PM   #17
5spd540
Yes I don't want to sacrifice the drivablility of it for looks. It not gonna be a daily but will get driven a good bit.
Old 05-21-2017, 06:28 PM   #18
68Stepbed
68Stepbed's Avatar
This is how my truck sat with a 4.5/6.75 drop. 18x9.5 wheels and 285/40/18 tires.
It's currently getting a TCI full front and rear coilover suspension, which should yield about a 5/7 drop. This is how she looks right now with no engine, fluids, or bed.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
