05-20-2017, 08:51 AM | #1 |
Center link orientation please...
After installation of the front suspension on a friends '68 I have concerns with the left side inner tie rod trying to rub the lower lip of the cross member. Just wanting to make sure everything is positioned correctly being I wasn't the one to take everything off for restoration...Thanks Ed
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
05-20-2017, 04:49 PM | #2 |
Re: Center link orientation please...
When the truck is off the stands and the tires on the ground with weight on them, it should clear just fine
05-20-2017, 08:19 PM | #3 |
That's great news, thank you for your reply...Ed
05-20-2017, 09:07 PM | #4 |
Center link position is correct. Looks great bud
05-20-2017, 09:46 PM | #5 |
Are you running an upper bump stop? I see you have a lower but cant tell on the upper.
Also, is your pitman arm torqued in these pictures? It looks like there are alot of splines above the arm. |
05-21-2017, 12:29 PM | #6 | |
1.yes 2.no 3.yes there were These pics were taken before final torqueing, thanks for asking... Thanks Randy for your response also...
