Old 10-21-2003, 09:47 PM   #1
Russell
Professional Grade
Russell's Avatar
Talking Victory!!
I told you guys I would make that truck run! Just need to fine tune my timing now, but I dunno what the marks are... I'm hoping someone else has a similar marker and can tell me what everything means...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-21-2003, 10:14 PM   #2
1FaastC10
1FaastC10's Avatar
using a timing light, line the mark on your balancer up with the notch indicated by the line. that will be 8* BTDC. that's generally about the point where most small block Chevys are happy.
1FaastC10 is offline   Reply With Quote
Old 10-21-2003, 10:15 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Can of Carb cleaner or Brake cleaner, rag, long screw flat head screw driver. There are numbers on the timing tab it the pic you show they are just hiding under dirt. Clean the tab of and you should see the numbers. Im working on a pic now
MylilBowTie is offline   Reply With Quote
Old 10-21-2003, 10:59 PM   #4
MylilBowTie
Right turn Clyde
Pic
For your 1980 GMC TRUCK C2500 3/4TON P/U 2WD:
TIMING SPECIFICATION 6 DEGREES BEFORE TOP DEAD CENTER *SET AT WARM IDLE SPEED (700 RPM) *DISTRIBUTOR VACUUM HOSE DISCONNECTED & PLUGGED *TRANSMISSION IN DRIVE (PARKING BRAKE ENGAGED) *ALL ACCESSORIES OFF
Old 10-21-2003, 11:01 PM   #5
Russell
Professional Grade
Russell's Avatar
Thanks, got it set to a little bit to the right of the far right tab, it seemed to idle best there... My engine is now complete
Old 10-22-2003, 12:30 AM   #6
1FaastC10
1FaastC10's Avatar
like at 8 after?
Old 10-22-2003, 01:24 AM   #7
Russell
Professional Grade
Russell's Avatar
Right to the right of the far left tab I should say
like 11 before sorta thing...
