Old 05-20-2017, 06:23 PM   #1
focusedontheprize
focusedontheprize's Avatar
Aftermarket X Brace
I have been looking around (in case I decide to go this route) of installing an aftermarket X brace. I thought Porterbuilt had made one, however I don't see anything listed on their website.
Has anyone come across aftermarket X braces for our year truck or had any direct experience with putting one in? I am not looking to make my own. Thanks.
focusedontheprize is offline   Reply With Quote
Old 05-21-2017, 02:28 AM   #2
hyperpasta
Re: Aftermarket X Brace
No limit eng makes a kit for the 55-59 series.
http://www.nolimitengineering.com/pr...tegory=6157546
hyperpasta is offline   Reply With Quote
Old 05-21-2017, 08:41 PM   #3
focusedontheprize
Apologies I should have mentioned I have a '49. Thanks for sending it over though.
Old 05-22-2017, 08:44 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
www.progressiveautomotive.com has one that's tube. You can use it on a boxed or unboxed frame. installs easy. I've used several of these
dwcsr is offline   Reply With Quote
Old 05-23-2017, 03:26 PM   #5
Kartch1
Sounds like you have some experience with these braces. How much of a difference do they make?
Kartch1 is offline   Reply With Quote
Old 05-23-2017, 08:56 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
When you box the frame and use this kit it takes out almost all the flex. we picked up the top frame with a forklift from the rear and it didn't dip at all. I picked up the left front wheel 2 inches off the ground and the right was almost off the ground.
Old 05-24-2017, 11:34 AM   #7
_Ogre
_Ogre's Avatar
dwcsr: that's a nice one, it braces the cab supports well
i realize focusedontheprize doesn't want make his own, but you could buy a welder and the steel for that price
thou with as much cutting, fitting and welding needed you can fab your own for a tenth of that price
i have less than $20 in this one and has the same support for cab mounts and trans mount
shop air compressor timer
Old 05-24-2017, 12:22 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
If you had nothing else to do I could see fabing one, but for $500 it comes preassembled. the sides are welded up and you just tack in the cross bars then cut of the tubes to slide into the frame. tack those and the weld up the connection points. Its far cheaper if your paying some one to do it or you'd would rather spend customer money into other areas that they see.
pluses are that its preassemble. comes ups, you could install in half a day if its your first one.
Making your own, find tubing go get tubing, buy the tubing bend cut cope joints, recut parts that are to long or short, one day shot, make tubes tack up fit and weld. another day.
I don't want to spend two days on a x member and save only a $100 . Were I short on money and long on tubing and time I'd make my own.
Old 05-25-2017, 06:36 PM   #9
_Ogre
_Ogre's Avatar
pro build vs my free time, i really had nothing else to do
if my time was figured in to truk, i couldn't afford it
Old 05-25-2017, 07:42 PM   #10
mongocanfly
Post Whore
mongocanfly's Avatar
Agreed with ogre...I don't know anybody that could afford me at the rate i work at...
.hahaha
Old 05-26-2017, 07:11 PM   #11
focusedontheprize
Thanks guys. I do have a welder, however this is something I would be worth spending the money on. Decisions decisions.
Old 05-27-2017, 12:31 PM   #12
Flysocal
I was gonna buy that kit from progressive it looks really nice. Decided on a full loop and boxed the frame should be good enough for me.
Flysocal is offline   Reply With Quote
Old 05-27-2017, 11:09 PM   #13
Kartch1
I think it would be pretty easy to make something similar to the progressive kit using square tuning and still have a strong braced frame. No bender needed.
