Old 05-21-2017, 12:52 AM   #1
69 c10 - dsm
Transmission Cross Member
I have a 1969 c10 with a 400 transmission, short shaft. I did get an after market one, but it didn't work with my truck. I'm looking/interested to know what others have used with this application. I have to assume that I'm not the only one. Thank you for your input/information I do APPRECIATE it.
69 c10 - dsm is offline   Reply With Quote
Old 05-21-2017, 06:23 AM   #2
Toms67
Toms67's Avatar
Re: Transmission Cross Member
Get one from 67-72 automatic transmission crossmember. Or performance online has them also. As well as other vendors. You may have to relocate to a different position. And drill some holes. Good luck.
Toms67 is offline   Reply With Quote
Old 05-21-2017, 07:51 AM   #3
69 c10 - dsm
The one I got was from Performance Online, which is a very nice piece, but when I had it on the truck, the cross member stuck out past the end of the tail shaft and when I put the yolk in it would not have cleared the cross member when it was rotating. (this was with the mounting tab to the front) I tried to turn it around (with the mounting tab in the rear, as suggested by POL) but then the cross member doesn't clear the bolts on the transmission case.
Old 05-21-2017, 08:42 AM   #4
69 c10 - dsm
Has anyone used products from Southwest Speed?? Quality/fit/price/tech support??
https://www.southwestspeed.com/index..._part&id=32029
