Old 10-21-2003, 10:31 PM   #1
Class of 69
Class of 69's Avatar
Question Front axle Q
Is a front axle from a 71 Blazer the same size, and mounting as my closed knuckle axle on my 69 K10? Will it bolt right in, or are there issues to deal with? Thanks, in advance!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 10-21-2003, 11:14 PM   #2
Beast388
Suburbans RULE!
Beast388's Avatar
Yep, it will bolt right up! The only thing you will have to deal with is the brakes. I bet the lines are different between the drums and disks.
Have you found axles yet? If not, mine are still for sale.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 10-21-2003, 11:18 PM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
probably need a different master cylinder and Porportioning valve if you are doing a drum to disc swap.
GO for it.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 10-22-2003, 09:49 PM   #4
Class of 69
Thanks guy's. I was aware of the brake line, and proportioning valve...just wasn't for sure it was a bolt in swap.
