Old 05-22-2017, 09:59 AM   #1
panhead59
converting from 6 to 5 lug
Is there some kind of wheel adaptor to go from 6 lug to 5 lug on the rear of a 68 swb? If so, how much does that affect wheel choice ( thinking of back space with 6" drop springs). Or do I have to go with axles? If that's the case, finding a "new" 5 lug rear would most likely be cheaper. Not building a hot rod that would require a "good" rearend.
panhead59 is offline   Reply With Quote
Old 05-22-2017, 03:47 PM   #2
bbbc10
Diggin The SquareLife
Re: converting from 6 to 5 lug
Stay away from adapters those things are dangerous jus get axles
bbbc10 is offline   Reply With Quote
Old 05-22-2017, 08:10 PM   #3
PGSigns
PGSigns's Avatar
Yup axles are the way to go. About the best price out there. https://www.summitracing.com/parts/y...FcmEswodoAoDbA
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-22-2017, 09:33 PM   #4
zach_carver
zach_carver's Avatar
I used early classic for my 5 lug conversion. It was actually Yukon axles though.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-23-2017, 01:54 AM   #5
andrewmp6
There is adapters but what a set of good ones cost you can also buy the axles in that link.The other thing is the adapters are thick like a inch or more which will push your rear wheels out that can cause problems with rubbing maybe.Its easier and safer to buy the axles trust me.
andrewmp6 is offline   Reply With Quote
Old 05-23-2017, 06:45 PM   #6
chris mc bride
chris mc bride's Avatar
Agree stay away from adapter . Think about it breaking at 70 mph and tire passing your spinning truck. How much will that cost you?
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 05-24-2017, 01:54 AM   #7
andrewmp6
I broke a ball joint on a car on a city road and they was a white knuckle ride tell i got it stopped.Hate to picture losing a wheel on the interstate.
Old 05-24-2017, 07:42 AM   #8
panhead59
OK, axels it will be!!! That's just what I needed to know. Thanks for all the replies!!!!! Next, I'll research changing out those axle seals while I'm in there. Don't know if they are pressed in or not. Never have changed axles before to be honest. I've got the chassis service manual and 40 years experience working on these old cars/trucks, so it shouldn't be too hard. I've just always farmed rear end work out to a pro. Thanks again!!! Heck, it may be easier and cost effective just to find a posi somewhere.
Old 05-25-2017, 02:31 AM   #9
andrewmp6
Do you want to change the diff to a lsd or change the gearing in it ?If so id wait and have a shop do it all for you if you don't trust yourself doing it.
Old 05-26-2017, 10:38 AM   #10
panhead59
I just need/want to change from 6 lug to 5 lug. Any 5 lug rears out there fairly close to Roanoke, (S.W.) Va. ?
Old 05-27-2017, 02:56 AM   #11
andrewmp6
Honestly that axle kit is cheaper then your gonna find a bolt in 5 lug rear end for it.They only made them a couple of years at the end of your body style.Anything else will take cutting and welding to fit and thats even if its the right width.
Old 05-27-2017, 08:26 AM   #12
panhead59
OK thanks. Yeah I've been looking around for a few days and not much luck finding a 5 lug. What years should I be looking for to fit a 68?
Old 05-27-2017, 11:06 AM   #13
Warrens69GMC
Warrens69GMC's Avatar
You have Leaf Springs or Coil Springs?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 05-27-2017, 07:26 PM   #14
andrewmp6
The half ton went 5 lug in 71 so 71-72 will bolt in as long as it has the same rear suspension as yours.But i think gm made those years rear ends a tiny bit wider it won't matter if your running stock style and size rims but if you want 20s or bigger then your back spacing comes in to play.
Old 05-28-2017, 07:44 AM   #15
panhead59
Coil springs. To tell ya'll the truth, I like the "deep set" look of 15" Craegers on the back. That would be more like zero backspacing wouldn't it? I don't even know if they make those anymore. Might have to go with a torque thrust or some other wheel to get correct backspacing. Anybody know how wide a rear tire one can go using the least amount of backspacing?
Old 05-29-2017, 01:51 AM   #16
andrewmp6
Its hard to say a backspacing with out known if your using the factory rear end or swapping to something else.
Old 06-01-2017, 08:50 AM   #17
panhead59
OK I got lucky (I think/hope) and was dreaming of this blonde.!!!!..... seriously, I found a '72, 5 lug rear with 308 gears. Not a posi but at least it should get about as good as u CAN get gas mileage. Bought it from a local junkyard for $375. I'll replace seals, brake cylinders, etc., and let her rock!!! Pretty happy since axles were gonna cost $300 or so. The next closest one from the junkyard site was in Ky., I beleive. Another in Ohio. 6 lug rear measured 55 1/4" from outter round lip on backing plate to other side, and the '72 5 lug is 57" from the same spots. So 1 3/4" wider. Should I just replace the bushings in the track bar or is there an advantage to buying a new adjustable one at this point?
Old 06-01-2017, 11:42 AM   #18
SCOTI
SCOTI's Avatar
Width difference should be 1.5" between the two housings.
The longer the Panhard bar (track bar) is, the better. Although both will get the job done, aftermarket long bars are better vs the factory short bars.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-01-2017, 05:18 PM   #19
panhead59
WHY BETTER ? Longer? I thought they were meant to center the rearend. If so, they should be the same length. Just wondering.
Old 06-01-2017, 05:43 PM   #20
SCOTI
SCOTI's Avatar
The bar centers the housing @ ride height. Compress or extend from that point & the bar swings on an arc which allows for some side shift. The shorter the bar, the greater the side to side movement as it travels through the arc.
The longer bar means less side shift during suspension travel. Not a big deal on a stock height truck but definitely more important when lowered.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-02-2017, 05:44 AM   #21
panhead59
Great explanation. I'm glad I asked. Thank you very much!!!!!!
