Turns over but no spark
I have a 454 in a 1972 Chevy Cheyenne. Put a new starter in and distributor coil. (It's a hei distributor) I put the new coil in cause the truck would turn over but wouldn't start. After the coil same problem but realized it was because the battery wire from the distributor came off so I ran it directly to the battery and the truck ran great. But it obviously wouldn't shut off. So I ran a switch for the wire and now it's back to turning over but no spark. I tested the battery wire into the distributor and it is getting power. Did the new coil go bad?
Re: Turns over but no spark
Is it getting 12v with key on and while cranking? Seems you have a switching issue to me.
HEi.. has a ignition module under the distributor cap that go bad. It's a fairly cheap plug in
Honestly my volt meter broke the other day so I was just using a test light. It is getting less voltage during cranking though because the light dimmed
Ive heard if that too and was thinking in trying that
