Axle code AY 345.1
I've looked at old threads to determine where to find my axle code and I looked on the guide, but my code is not on there. Any ideas?
Edit: it says AY W345.1 |
Re: Axle code AY 345.1
Here's a pic
I looked over the codes again and found RAY under 1972 showing 3.07. Maybe the PO swapped it out. My truck is 1971.
![]() Join Date: May 2001
It should be a 3:07 based on your spid. 70-72 axles should have 3 letter codes. Check and make sure there isn't another letter in front of the ones you found. It could be lightly stamped. I have a book of codes I can look at when I get home.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
Thanks. I'll look for another letter when I get home. Where do you see that on my spid?
Standard axle ratios are mot listed on a SPID. A 1/2 ton, 350 automatic would have a 3:07 gear as standard
![]() Join Date: May 2017
Looking at your picture there is a very lightly stamped "R" in front of the "AY"
