05-24-2017, 11:05 AM | #1 |
Short Bed 4x4 Stock vs 4" lift
Does anyone have a picture of a stock height and a basic 4" lift. It has been so many years since I worked on one of these I can not tell if mine is lifted or not. I have been looking at picts in Google for hours and I think the 4" lift is higher then I want to go. I thought these trucks sat lower then it seems.
I will try to find a picture of the height I want mine and maybe you all can tell what it. I don't want 35's. I think 33's will work well. This is mine and I think it is stock. It has about a 2" block in the rear and flat front springs. This is the height I want it:
79 C10 Stepside, on 22's, 350, AFR 2.02 Heads, Victor Jr, Holley 770 Ultra, 12 bolt 3:73, 700r4... Last edited by frenchsquared; 05-24-2017 at 11:14 AM. |
05-24-2017, 12:56 PM | #2 |
Re: Short Bed 4x4 Stock vs 4" lift
I am thinking yours is about stock height...especially if your front springs are flat. There is a thread on here pretty recently with trucks with 2" of lift, which appears to be what you are after.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
05-24-2017, 01:38 PM | #3 |
05-24-2017, 01:40 PM | #4 |
Thanks... I think 2" is about right. 4" with 35's is taller then I want. Thinking about getting the 3" ez ride lift. Good price and will replace worn out parts.
79 C10 Stepside, on 22's, 350, AFR 2.02 Heads, Victor Jr, Holley 770 Ultra, 12 bolt 3:73, 700r4... |
05-24-2017, 01:41 PM | #5 |
Nice truck... thanks. That tells me for sure I want my short bed a little lower.
05-24-2017, 03:36 PM | #6 |
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
