Old 05-24-2017, 06:12 PM   #1
Materman
Materman's Avatar
In over my head.... HELP!
Back a few months ago I decided to thrust myself I to the strange new world (to me anyway) of LS swapping my '72 GMC Sprint (el Camino) but now I realize I'm not sure what to do....
Here's my issue:
I bought a 5.3 with wiring harness and ECU out of a wrecked '08 Silverado 4x4 z71, I would really like to rewire/Repin the wiring harness myself, but cannot find a schematic for the newer E38 ECU, only for the older computers. I also was told that my '99 4l60e I have for this project will not work because its a '99 2wd tranny and I have a '08 wiring harness for a 4x4 tranny. Question #1: is there ANY wiring how-to's out there on the new harness? Question #2: will my tranny work somehow and if so, what do i need to do?
Any suggestions/help is really appreciated because I'm really starting to reconsider this whole mess!
Thanks, Richard
1969 GMC 1/2 Ton
1955 Chevy 4400 series 1.5 ton truck
1949 Dodge Coronet
1972 GMC Sprint 350 with th400
Not bad for a 20 year old!!!
Materman is offline   Reply With Quote
Old 05-24-2017, 06:26 PM   #2
Bigdav160
Bigdav160's Avatar
Re: In over my head.... HELP!
I am not at work so I can't help you with the wiring diagram but I think your source is right about the transmission. An '08 computer will be looking for an input speed sensor that the '99 transmission does not have.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-24-2017, 06:39 PM   #3
Materman
Materman's Avatar
Aww, man! Do I have to find another tranny?
1969 GMC 1/2 Ton
1949 Dodge Coronet
Old 05-24-2017, 07:37 PM   #4
crakarjax
crakarjax's Avatar
http://lt1swap.com/geniv_harness.htm
I'd try ls1tech.com for questions, but make sure to search that forum for answers first because your questions are probably already answered there. For instance https://ls1tech.com/forums/automatic...rly-4l60e.html
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-24-2017, 07:39 PM   #5
davepl
davepl's Avatar
I'd think your worst case would be to run the ECM as though it were a manual trans and then control the 4L60E with a standalone box. Neither would know about the other, but both should work independently.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-24-2017, 07:59 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Hit up clinebarger here on the forum, he is the trans guru here and does LS swaps for a living too.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-24-2017, 08:18 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
E38 ECU pinouts
http://lt1swap.com/E38%20ECM%20Connector%20Pinouts.htm
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-25-2017, 12:33 AM   #8
First c10
First c10's Avatar
What 99 vehicle did the trans come from?
I have a 4.8 out of an 08 with 4L60 trans.
I do believe the e38 ECU can be re programmed for the 4L. It is the 24 crank trigger it does not support. (If I am not mistaken).
As for the pin outs....above are what I used a few times. It has worked for me. Brenden is a beast and can also help if you have questions.
Attached is a picture if the connector on my 4L60 it is a 4x4 trans but should not be any different other than the VSS sensor is on my transfer case instead of the transmission tail housing.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-25-2017, 01:07 AM   #9
dayj1
Unfortunately, bigdav160 is right. You'll need a different trans because of the input sensor that is needed for the e38/t42 combo.
It is possible to retrofit at least some of the 4l60 transmissions with an ISS by swapping input shafts, pump housings, internal wiring harness, and the ISS sensor its self, but I don't know if that can be done with a '99 model or not. As suggested, clinebarger would be able to answer that question, but I don't think I'd choose that route due to the expense and/or time required.
dayj1 is offline   Reply With Quote
Old 05-25-2017, 01:16 PM   #10
Materman
Materman's Avatar
Well, alright..... I had hoped I hadn't messed up getting this tranny, its out of a '99 tahoe, but at least I only paid $150 for it.
As far as the pinouts, this may seem stupid, but how do you know which wire is #1,#2,#3...etc? It isn't making sense to me lol
1969 GMC 1/2 Ton
1949 Dodge Coronet
Old 05-25-2017, 09:39 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Look at the top of the page where the little picture of the connector is. Each connector is labeled (J1, X1, X2 etc). And it should show you where pin #1 is, and gives the pin # for the starting and ending pin on each row in relation to the connector. (NOTE the location/orientation of the connector itself)
So pin #1 is the pin on the TOP row all the way to the RIGHT. Opposite the large primary pin (#73)
Old 05-26-2017, 11:03 AM   #12
Jstock85
Dont panic mater! swapping trans won't be a problem. And these guys are right about lt1swap.com. that website has all the info you'll need and the guy who runs it will walk you through any problems
Jstock85 is offline   Reply With Quote
Old 05-26-2017, 03:35 PM   #13
Materman
Materman's Avatar
Ohhhh!!! It was right in front of me!! Thanks 😃
1969 GMC 1/2 Ton
1949 Dodge Coronet
Old 05-26-2017, 10:12 PM   #14
Materman
Materman's Avatar
Alright, I have yet another question, what fuse block have you guys used? I keep reading about ford Taurus fuse blocks, etc... But have no clue where to start.
Sorry for all the questions guys, I just wanna get this right so I can do it again one day easier on another project rattling around my brain....
1969 GMC 1/2 Ton
1949 Dodge Coronet
Old 05-27-2017, 02:01 AM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
just buy one. Don't try to pull a block from the salvage yard, unless you really feel the need to use a donor block from the same truck (i.e. using an 08 silverado block to keep everything "matched").
There's a recent thread in this section talking about some of the recent problems with the fuseblocks the harness makers are using, most of which look like the cheaper wholesale blocks you can find all over.
A good quality universal fuse block is all you really need, and can be scaled up or down depending on your needs. I have 2 fuseblocks, one for my body and one for the engine/drivetrain, about 12 fuses each. Some guys slim down and put it all on one, others scale up and add extra slots or splitting things off.
