![]() Join Date: Jan 2017
consoles
can someone tell me what kind of paint to use on a console? and what color i should use for a 510 medium blue truck ? any help would be most appreciated
thanks Pete |
Re: consoles
On my Dark Blue truck it was body color.
How detailed do you want to get? Here's my rough approach, from memory: - Scrub like crazy with strong soap and water - Clean with plastic prep spray - Wipe with plastic adhesion wipes or sponge - Shoot DP90LF Primer - Shoot Color Coat PPG DCU - Shoot Clear Coat PPG 2060 "Flexed'n'Flat" Keep the coats light and the stuff well reduced to avoid filling in the grain. If you don't want to buy guns and compressor and materials you can get a lot of these products in rattle can (like the SEM line mentioned below) but I don't know about the color coat.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 05-26-2017 at 12:15 PM. |
#3 | |
Re: consoles
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: consoles
SEM makes great products for this, lots of color choices too.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: consoles
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: consoles
Had my blasted and I not sure which media used but was a blasting business shop that did it. I havent painted it yet but will be using SEM 15103 to match my parchment interior. I got that SEM number form a board member that has done lots of consoles.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#7 | |
Re: consoles
Pete |
