Old 05-25-2017, 12:00 AM   #1
FL71C10
292 Power Steering
Anyone got a 292 PS setup?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 05-25-2017, 07:32 AM   #2
1rippen6
Re: 292 Power Steering
I have this one I read where they are the same but please check for yourself because I don't really know.
http://67-72chevytrucks.com/vboard/s...d.php?t=728527
1rippen6 is offline   Reply With Quote
Old 05-25-2017, 08:06 AM   #3
FL71C10
I'm not sure either. I have read that the 250 setup will work with some mods. I'd like to see if someone has a 292 specific setup
Old 05-25-2017, 09:15 AM   #4
jfnar
I'm using this one: http://www.ebay.com/itm/10003-292-CH...VSDYLo&vxp=mtr
The water pump on a 292 is different than a 250; this bracket accommodates the bypass hose. The fit was not perfect but I was able to make it work ok.
jfnar is offline   Reply With Quote
Old 05-25-2017, 04:27 PM   #5
FL71C10
Wow, that's funny, I've been looking at this one.
ahttp://www.ebay.com/itm/321360864871?ul_noapp=true
It's disappointing to hear that it didn't fit just right.
Old 05-25-2017, 07:04 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
I believe the 292 engines have different pulley spacing. If a 250 set up was used you would need every component to ensure pulley alignment, including the damper.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-29-2017, 09:52 AM   #7
FL71C10
Anybody with an original 292 specific ps setup?
Old 05-29-2017, 05:14 PM   #8
southern parts
southern parts's Avatar
250 power steering won't' work on a 292. The 292 block is about 2" taller than a 250
southern parts is offline   Reply With Quote
