Old 05-25-2017, 08:04 AM   #1
James903
Upper and lower A arm shafts
I'm rebuilding my front suspension. Replacing ball joints, tie rods, shocks, and coils. I'm using moog ball joints and tie rods which I already have. I noticed that moog also sells the upper and lower A arm shafts. They cost a bit more then the shafts Lmc truck has. So basically my question is am I going to pay extra for the moog name or should I just go with the less expensive shafts Lmc truck sells? The total cost difference is about $40-50 if I go with the moog, which I have no problem with if I'm getting better quality.
James903 is offline   Reply With Quote
Old 05-25-2017, 08:46 AM   #2
71PICKEMUP
71PICKEMUP's Avatar
Re: Upper and lower A arm shafts
I got my Moog parts at rockauto.com. Saved a lot of money.
71PICKEMUP is offline   Reply With Quote
Old 05-25-2017, 10:27 AM   #3
James903
Thanks 71pickmeup, you saved me about $40. Rock auto is definitely cheaper then the other site I was looking at.
Old 05-25-2017, 10:49 AM   #4
chevylookin
My moog u-joints always fell apart like a $2 watch on my Blazer before I got the CV joint. Yes, the pinion angle was off but I actually had a moog u-joint last less than a day. Overpriced imo..
chevylookin is offline   Reply With Quote
