Anybody using the Hydratech System?
It's similar to what some Ford and GM vehicles have had in the past. Not sure if any still do. It utilizes pressure from your power steering pump for your power brakes. It's bolt in. No vacuum problems with big cams. They recently added our trucks to the applications although I don't think they are on their website yet.
Hydratech
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
Yeh It's Fast
Yeh I wanna know to
i'm going to send them an e-mail
![]() ![]() ![]() ![]() Click here to view pictures of my truck ![]() ![]() ![]() ![]() Zwijndrecht, The Netherlands Europe |
F.A.S.T. president
![]() Join Date: Sep 2003
They still come factory in most 1 ton and bigger trucks and busses. The only negative part is, if your engine ever shuts off you loose your power brakes instantly. With the vacuum assist it will give you a couple of pedal strokes before you loose it.
Firefighter
Also with that kind of setup, if you are low on power steering fluid and hit the brakes it will sometimes jerk the wheel out of your hands. My buddy has the hydro boost setup on his '69 and absolutely hates it!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Formerly yellow72custom
They were available from the factory in these trucks.
I haven't used one, but from what i understand, if your tranny is in gear, and you try to use the brakes and steering while idling, it has a hard time using both. If you have problems running power brakes with a big cam, you can get a vaccum canister that will store engine vaccum so you can use it when you hit your brakes ![]()
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
I'm sure it has some disadvantages but IMO the advantages are greater. No vacuum worries, lot cleaner set up and uses less space. Decreases stopping distance. A lot of the pro-touring guys love the crap out of them and they're real picky about what they use (they aren't going to top of a $2500.00 Baer or Wilwood brake set up with something that is only marginally better than what they already have).
I'm sure the aftermarket are much improved upon the factory systems, also. I realize there was some issues with those.
Sisyphus was my mentor!
![]() Join Date: Sep 2002
My girlfriends dad has the hyrdobost on his Chevy 6.2l Deisel & he thinks is ok BUT turning and braking at the same time are not fun - the steering gets stiff & the brakes get weak. His diesel is on its way to 10000lbs loaded with all his construction tools but I think that if you overboost the pump a bit its a good idea.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Again, on most GM power steering pumps the amount of shims can be changed to in/decrease pressure if necessary. And again if these issues were true the pro-touring guys wouldn't be using them. I think the last thing they would want would be to worry about applying the brake at 170mph in a sweaping right hander.
Try spinnin 4 rear tars
My dad's '01 Dodge Cummins has that kind of setup on it. I really like it. I barely notice a problem when turning and braking! I've been thinking really hard about buying a kit for my truck!!!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
Firefighter
Just wait until a power steering hose blows while going down a really big hill pulling a big load with a sharp corner at the bottom!! Then we'll talk about how well you like that setup!! (If you are still alive!!!!) I'll take the good ole vacuum setup any day over the hydroboost!! Also 68LSS1 what do you mean CLEANER SETUP???? They have several lines under the hood, and just wait until they start leaking!! Then it's not so clean!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() Last edited by BLACK AND BLUE 67-72; 10-22-2003 at 10:25 PM. |
#11 | |
F.A.S.T. president
You can find good and bad things about both systems. For my vehicles I will stick with vacuum. We have both systems in our fleet of thousands of vehicles. I have 600 vehicles assigned to my shop and only about 5% are hydraulic boost. Never seen any real failures with either system.
On some of the heavier units they have an electric hyd pump back up systems. When the hyd pressure from the power steering pump drops the electric system kicks in and keeps the pressure up in the brake booster, even with the engine completely off. But with a half ton truck and everyday driving the vacuum booster works fine. @68LSS1 Did you finish installing your diff? How about some pics. |
