Old 05-25-2017, 11:51 PM   #1
Abnrml1
Cab Swap
I'll be getting a '85 cab next month to replace the rusted out one on my '78 K15 and I'd like to know if I will have to pull the trans hump from the K15 or can I just cut a hole in the new cab for the transfer case shifter. I really don't want this to be a hack job so I thought I'd ask. Thanks.
Abnrml1 is offline   Reply With Quote
Old 05-25-2017, 11:58 PM   #2
Matt Man
Matt Man's Avatar
Re: Cab Swap
If the 85 cab was either 4 wheel drive and I think if it had a sm465 trans (manual) it will have had the high hump trans cover.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-26-2017, 06:20 AM   #3
cadillac_al
Re: Cab Swap
Around here guys use a 2" body lift and a small hole for the shifter.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-26-2017, 10:38 AM   #4
CSHADES
CSHADES's Avatar
Re: Cab Swap
The floor and center humps are different in the 73-80 to 81-87 trucks. You will need a center hump from a 4x4 81-87 truck. If you look at the thread I have on my "rebuilding my 1977 plow truck" It covers a lot of the issues you will go through on replacing a older cab with a newer cab. there are also issues to deal with on the front end if you are going to use the old style front end with the new style cab.
CSHADES is offline   Reply With Quote
