Old 05-26-2017, 12:48 PM   #1
BLUE49
64 Rear Brake Drum
I have a 49 Chevy 3100 with a 64 GMC rear end. I need to replace a rear brake drum and it seems like finding a new one isn't possible. The drum is actually made in 2 pieces. The outer rim is cast iron and the "hub" is steel with the two pieces welded together. The dimensions are : 11" I.D. x 2-1/4". Overall height is 3-1/4". I've tried all the on line people like Brothers, Jim Carter, etc. Any suggestions where I can find one?
BLUE49 is offline   Reply With Quote
Old 05-26-2017, 01:01 PM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: 64 Rear Brake Drum
That rear drum is the same as the fronts. There are constantly people on here giving away front suspension parts who have coverted to disc. Post a WTB ad or check the "Paying it Forward" thread. Should be easy to find one.
VictoriaHardware is offline   Reply With Quote
Old 05-26-2017, 04:18 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
Can you post a picture of that two piece rear drum? In all the trucks I have seen and worked on, I never heard of a two piece drum...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-27-2017, 01:42 AM   #4
Captainfab
60-66 Nut
A '64 GMC should have a Dana 44 differential. Those are very difficult to find drums for. A standard 12 bolt drum will not work. There is a thread here about one guys quest to find drums for his Dana 44. Sorry but I do not remember the members name or the drum he found to work.
Old 05-27-2017, 01:52 AM   #5
MusicMan70
MusicMan70's Avatar
This one? http://www.67-72chevytrucks.com/vboa...d.php?t=614719
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-27-2017, 12:44 PM   #6
BLUE49
I attempted to send a pic of the drum but was unable to. I've decided to go to a disc brake conversion, which begs the question, "How do I identify a Dana 44 diff"? Appreciate any help with this. I will keep trying to send a pic.
Thanks.
Old 05-27-2017, 01:47 PM   #7
sirJim
Thanks.
Might help a bit.
sirJim is offline   Reply With Quote
Old 05-27-2017, 05:56 PM   #8
BLUE49
A picture is worth 1000 words! I have the DANA 44. I never cease to be amazed at the knowledge that exists on this website. Thanks for all your help.
Old 05-27-2017, 11:54 PM   #9
Captainfab
60-66 Nut
Yes that is the thread I was thinking of......Thanks MusicMan70
Originally Posted by MusicMan70 View Post
Old 05-28-2017, 12:16 AM   #10
Praxiss454
Praxiss454's Avatar
The rear drum on a GMC rear-end is not the same as the front drum. The GMCs had rear leaf springs, not coil springs, and as a result, the rear drums are fatter from outside to inside.
I ended up getting some Wagoneer drums that were the right pattern but wrong hole sizes, and had them machined. It was expensive, but I am confident the shoe is making full contact with the drum, unlike going with a narrower drum. You can read the specifics in this thread. (as previously posted by MusicMan70)
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
