Old 05-26-2017, 04:00 PM   #1
michael bustamante
michael bustamante's Avatar
Camaro oil pan help
Ok a lil delima here. The cover that goes inside the oil pan. Do i need to replace it with camaro one or can i use the one on the truck motor?
If i need to replace it with the camaro one though the back 2 bolts do not line up and ill have to drill new holes in the cover
Motor is a 5.3 from a yukon 2004
1967custom
michael bustamante is offline   Reply With Quote
Old 05-26-2017, 05:40 PM   #2
michael bustamante
Re: Camaro oil pan help
Also.is there a trick to mounting the gasket? Those alignment pegs are messin me up!
1967custom
Old 05-26-2017, 05:49 PM   #3
crakarjax
crakarjax's Avatar
I used a camaro pan with camaro windage tray (like $25 shipped on ebay fyi) and had no issues with bolts lining up. You could also modify the truck windage tray, it's a pretty simple piece after all.
Not sure what you're referring to with aligning the gasket, as the bolts should line it up pretty easily. I did not have any alignment pegs on mine afaict.
Now that I think about it, I think you might have the wrong pan... the back bolts definitely line up on my 2004 ecalade engine to the f-body pan.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-26-2017, 07:43 PM   #4
michael bustamante
Yup they did. I just didnt mock it up back far enough. Lol
Another question. I cannot remember for the life of me what hooked up to this.
1967custom
Old 05-27-2017, 07:43 AM   #5
homemade87
There most likely was nothing hooked up to that piece unless it was drilled and threaded . I drilled mine out and put my oil sending unit in it for my gauge .
homemade87 is offline   Reply With Quote
Old 05-27-2017, 10:11 AM   #6
Jstock85
Im currently working on a 4.8 and nothing was connected there on mine. i think its there to give you options similar to what homemade 87 did with his.
Jstock85 is offline   Reply With Quote
Old 05-27-2017, 04:07 PM   #7
michael bustamante
cool. im tapping it today then
1967custom
Old 05-27-2017, 10:17 PM   #8
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
The tapped ones are for oil temp senders, corvette only I think.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-30-2017, 02:16 PM   #9
akdg87
akdg87's Avatar
You can cut the truck windsge tray to work with the ls1 oil pan. I did it and it works plenty fine. Just google it.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 06-01-2017, 10:34 AM   #10
Hart_Rod
Hart_Rod's Avatar
Make sure you drill it out also...
Hart_Rod is offline   Reply With Quote
Old 06-01-2017, 11:27 AM   #11
68Stepbed
68Stepbed's Avatar
Use the correct windage tray and pickup tube with the corresponding oil pan. They're different for a reason.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
