05-27-2017, 01:26 AM | #1 |
Question about lowering my truck
I've been thinking for a while now about lowering my truck some - probably with drop springs and leaving the two inch blocks in place. With these 15" rallye wheels I can see that I am in a "danger zone" situation the way my hardware rests below the wheel rims in the back. Will drop springs make this problem worse by lowering the trailing arms further? The suspension is all courtesy of the previous owner. Thank you.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-27-2017, 05:40 AM | #2 |
laying low
Re: Question about lowering my truck
No drop springs on the rear won't affect the scrub line. More spacer blocks will.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-27-2017, 05:59 AM | #3 |
Hi Ned, Shorter springs won't make trailing arms any lower, just the frame and body! Show us Your truck as it sits now!
05-27-2017, 07:42 AM | #4 |
Thanks for the input, guys. Here is a pic from the side
05-27-2017, 08:28 AM | #5 |
What looks scary are the homemade blocks and scrap metal stacked in there. You might want to replace all that with a solid 2 inch block and new u-bolts. Unless you have 2 flat tires at the same it won't scrape the road.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
05-27-2017, 08:31 AM | #6 |
For sure. I'm looking right now at parts
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop Last edited by OregonNed; 05-27-2017 at 08:31 AM. Reason: Misspelled word |
05-27-2017, 01:04 PM | #7 |
Ned it looks good the way it is!! Not the blocks.
