Old 05-27-2017, 03:53 PM   #1
rockyrivermark
Fuel gauge wire at fuse panel
1970 c10
My fuel gauge been acting a bit strange.
I checked for power where the tan lead connects at fuse block. I tested It for power with a tester with light bulb. The bulb was dim.
That should be a 12v source right?
Thanks for any help you can provide.
Thanks.
Mark
rockyrivermark is offline   Reply With Quote
Old 05-27-2017, 04:52 PM   #2
harpo231
harpo231's Avatar
Re: Fuel gauge wire at fuse panel
The easiest way to troubleshoot fuel gauge problems is at the sending unit. Don't mess with the cluster or fuse box until you do this first: Slide your seat forward, and with the key on disconnect your tan wire at the sending unit. Your gauge should now read about 3:00. Now ground the tan wire against the top of the sending unit, or the fuel tank, or a known good ground. The gauge should now go to empty. If those two steps work, everything is working properly all the way back to the gauge.
That tells you the problem is in the sending unit <<<< from bstock
harpo231 is offline   Reply With Quote
Old 05-27-2017, 04:58 PM   #3
harpo231
harpo231's Avatar
True doc if your gauge has regulator . if in sender should be less
Old 05-27-2017, 05:24 PM   #4
rockyrivermark
Yes. I know that test. Truck is in middle of restoration so it's somewhat stripped.
I just thought it odd that the power from that connector at fuse block was weak.
Is that wire to the fuse panel a 12 volt source for the sending unit? I'm guessing it is
If so I would pick up that power elsewhere since it's weak.
Old 05-27-2017, 05:59 PM   #5
harpo231
harpo231's Avatar
gauge reads resistance (ohms) so dont want full voltage
Old 05-27-2017, 06:14 PM   #6
rockyrivermark
the question is:
Is the tan wire a 12 volt source?
Old 05-27-2017, 06:44 PM   #7
harpo231
harpo231's Avatar
NO 12 v comes from ign switch
Old 05-27-2017, 06:52 PM   #8
rockyrivermark
Ok. So that tan wire connects to a voltage Lower than 12v right?
If so got it.
I cleaned up conendctor at sending unit and it seems fine.
thanks for the info.
Mark
Old 05-27-2017, 07:08 PM   #9
harpo231
harpo231's Avatar
np
