66 C10 Carb question?
I am somewhat clueless about Carbs, while cleaning the engine bay and engine I thought I had broken a line to the carb. I believe its the original Rochester Carb, the line in question in the picture was attached by a rubber type union or cover. Today when I got the engine ready I started and ran it for a while with absolutely nothing wrong, no gasoline coming out either side of the line. Is this some kind of breather line? or a line that was eliminated for some reason? any help will be appreciated, apologies for the bad pictures.
1966 Chevy C10 Not named yet, help! 1984 GMC 4x4 SB "The Hunter" My 66 C10 fun build: http://67-72chevytrucks.com/vboard/s...d.php?t=738705 |
Post Whore
![]() Join Date: Mar 2013
Re: 66 C10 Carb question?
From what I can see...that is your vacuum advance line. That line will go from the carb to the little pump on the distributor.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#3 | |
Yes, that is exactly where it goes, now pardon my complete ignorance, what does it do? ![]()
I googled it with the name you gave me and now understand, thanks!
It also has another deleted line...
That is not the correct carb or factory carb you have there
I saw a carb just like that on a 67 or newer truck in the pick n pull yard. Definitely different from a stock 66 carb.
Post Whore
You Nailed what is does! lol! It's your vacuum advance. ![]()
Post Whore
WRONG, the later model 250's and 292's came with monojets.
When my carb was off I measured its bore diameter at 1 9/16" The diameter in the manifold was 1 5/8". I think I read that 250's get 1 9/16" carbs and 292's get 1 5/8" carbs. Do they do the monojets the same way?
Post Whore
I'm not positive, but most likely yes they do.
The Monojet came out in 1968. It worked for the new emission laws. 1976 on back had the Roch. model B. The MJ used on 292 engines did have a larger throat & venturie then the 250. Often they have been changed around as the rebuilders don't separate them.
That vacuum outlet might go to the modulator if it has an automatic trans. The dist vacuum was generally hooked to ported vacuum which has an outlet on the other side. |
#13 |
#14 | |
Post Whore
Um, Why are you telling me this??? I was the one stating in the first place that these came with monojets in the LATER years. Had nothing to do weather it was Factory or not...it had to do with the fact you stated they were not Correct for these engines at all when...Yes...indeed they were for later years. And to show that once again the "I've never seen one yet" knowledge is not a valid reason that they were not used. If I could have a dollar from every person that sated, "I've never seen a GMC 305 v6 therefore they don't exist." I would be a millionaire!
#15 | |
