05-28-2017, 12:54 PM | #1 |
Replacing window handle crank
Might be a stupid question, but can someone tell me how to get the window handle crank off so I can replace it. Went to roll the window down yesterday and the cheap plastic cracked. Thanks in advance.
1967 Chevy C10 Stepside SWB - 350/700r4 |
05-28-2017, 01:03 PM | #2 |
Re: Replacing window handle crank
They make a tool to reve the clip on the back side of handle.You can do it with a pocket screw driver but it's a pain!!
05-28-2017, 01:36 PM | #3 |
05-28-2017, 03:00 PM | #4 |
BlahBlahBlah
On mine if you slam the door hard enough they just fall off =)
You can push in a little on the door panel where the crank goes in and look in there. When you slowly rotate the crank you can see the clip they are talking about. One end is open and one end has a small bit of loop you can grab, or you can use the tool posted earlier. I have a metal wire with a small hook in it that I fish in there and just pull it off. When you go to reinstall I just put the clip on the crank and push the crank over the shaft carefully.
05-28-2017, 03:20 PM | #5 |
Get the tool... I know it's annoying but everyone needs one and while it's theoretically possible to get lucky and pop the clip off with a screwdriver or similar, I've never managed to. But the tool makes it trivial.
05-28-2017, 03:55 PM | #6 |
Just get a fish hook dull the point, or get the little screwdriver style hook. Push the pad back enough to hook the little clip and pull it out. Then the handle just pops off. No need for a special tool. Any little piece of wire or coat hanger will work in two seconds flat.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
05-28-2017, 04:07 PM | #7 |
A shop rag spun around the crank will pop the clip off...
05-28-2017, 06:10 PM | #8 | |
Works every time
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
05-28-2017, 07:15 PM | #9 |
I agree, works like a charm. The tool inserts parallel the handle. If you can't find the clip then it's on backwards.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-28-2017, 07:32 PM | #10 | |
I've done it that way for 40+ years. Hook the open end toward the handle (away from the door panel) and it has never damaged anything... Have used that on all types of Chevrolet handles... Impala, Camaro, C/K Truck, Nova... Works on them all... |
05-28-2017, 08:04 PM | #11 |
I splurged and spent the 5.99 for the tool at Orielly's, worked like a champ. Popped both old ones off and replaced with new ones. Thanks for everyones help.
06-01-2017, 09:42 AM | #12 |
BlahBlahBlah
I was working on my door panels this weekend and I had heard of the wrapping a shop rag around the shaft area like franken said. I gave it a shot just to see how well it works. It works super easy, not really sure how it does it but the clip came right off. I still like using my little spring hook. It does look like picking one of those clip removers for 6 bucks is also another cheap and easy option
06-01-2017, 11:13 AM | #13 |
I've allways used the shop rag trick when scouring the jy's. Theres is always plenty of rags found in the vehicles.
I've had times at home when I get them off quicker with the rag than with the tool.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
06-01-2017, 01:52 PM | #14 |
x1,000,000
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-01-2017, 10:10 PM | #15 |
I am a Referee of life.
BTW Those clips are called "Jesus" clips because that's the most common exclamation when they fly away. That's what I was told as a youngster but I've never been able to be that civil.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-02-2017, 06:50 AM | #16 | |
I managed to pick up a snap on window crank clip tool at a swap meet for $5 and somehow it does not send the Jesus clip flying into the fifth dimension. |
