![]() Join Date: Jan 2016
Rear coil removal
I read the proper procedure here to accomplish this and it would have worked great if it weren’t for rusted bolts. I did get the bottom nut and bolt on the driver side off, but the bottom passenger side ended up getting a date with my grinder. Now my question. Is the a trick to getting the top nut and bolts off? I am assuming there is a nut inside the frame but I can't see in there and can barely get my hand in there to feel the nut much less get a wrench on the nuts.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
#2 | |
Re: Rear coil removal
http://www.classicparts.com/mobile/1.../#.WSzIFHplDqA Thankfully my bottom bolts didn't snap cause I endid up having to reuse my original ones cause the 3/4 ton bolts on the bottom are longer than the ones on a 1/2 ton. |
#3 | |
#4 | |
