Old 05-29-2017, 04:21 PM   #1
LuckyScott
LuckyScott's Avatar
How to make your blazer drive better?
I have a 72 Blazer that is lifted with big off road tires. It wanders a lot going down the road. So I replaced the steering box and the power steering pump and made it better. But it is still not as good as I would like.
I read a thread about a guy replacing his steering box and someone posted this........
"I hope that the steering box will solve your on highway driving. I changed mine with no difference checked balls everything come to find out rear springs were rocking back and forth. Spring pads were misaligned so i aliened the pads solved the problem. Good luck"
That made me think where to look next to try to improve the steering and make it easier to drive.
Any suggestions?
LuckyScott is offline   Reply With Quote
Old 05-29-2017, 04:30 PM   #2
hemi43
hemi43's Avatar
Re: How to make your blazer drive better?
Tapered shims between the front springs and axles for more caster. I'm running 6.5 degrees total and have 12.5 X 33 tires. I've had it over 80 with no issues.
Don't go with a high ratio box, because it will make things worse. Blazers with 104 wheel base are too short for quick boxes if you plan on driving it at higher speeds.
hemi43 is offline   Reply With Quote
