05-29-2017, 05:32 PM | #1 |
Horn Questions
Do we need to use a relay for the horn to work on a 1960 GMC with a V-6? I have E-Z wiring and I don't see the hook up? I found this drawing and it seem generic enough.
http://s1299.photobucket.com/user/jb...23904108567829 |
05-29-2017, 06:18 PM | #2 |
Re: Horn Questions
Yes, you need a relay, and yes, that diagram you found will work.
The horn button in the steering column is on the ground side of the circuit so it can't be used to feed power directly to the horn. But it can be used to trigger a relay that will send power to the horn. |
05-29-2017, 06:34 PM | #3 |
Re: Horn Questions
Thank You
05-29-2017, 10:48 PM | #4 |
Re: Horn Questions
Need to order a relay. Any one have a good part number?
05-29-2017, 11:36 PM | #5 |
Re: Horn Questions
NAPA shows Echlin part number as:
ECH HR113 |
05-30-2017, 09:16 AM | #6 |
Re: Horn Questions
I called EWZ-Wiring and they have the relay wired in as part of their fuse block wiring, so I must be having horn contact issues. They said ground the horn from the block that goes to the column and see if that causes it to blow.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 05-30-2017 at 01:29 PM. |
