Old 05-29-2017, 10:02 PM   #1
65truckowner
65truckowner's Avatar
1987 blazer
My son is thinking about buying a 87 blazer with 65000 miles on it. 350 auto. Nice shape what are some pros and cons on this trucks.
65truckowner is offline   Reply With Quote
Old 05-30-2017, 12:09 AM   #2
abig84
abig84's Avatar
Re: 1987 blazer
Biggest issues I always ran into in the Midwest is rust issues. Floors love to disappear. Also the frame can crack by the gear box but can be fixed. Very easy to work on and very reliable in my experience
abig84 is offline   Reply With Quote
Old 05-30-2017, 09:12 PM   #3
65truckowner
Re: 1987 blazer
The good thing about this one is it it super solid no rust. The guy says on the road it will get 18 mpg. It is a good looking rig so I thing we are going to buy it and he is going to drive it
Old 06-02-2017, 08:31 AM   #4
65truckowner
Re: 1987 blazer
bought the blazer a good solid ride. It has a chrome wind deflector or something above the back glass on the top. What is it? I will try to get some pic soon
Old 06-02-2017, 10:54 AM   #5
Keith Seymore
Keith Seymore's Avatar
Re: 1987 blazer
It's probably an aftermarket or accessory wind deflector to shoot the air down across the back window, both to help keep it clear and perhaps to reduce drag and improve fuel economy. Whether it works or not is up for debate.
Since you didn't get a lot of input, I'll take a shot:
Pros -
It's 90% the same as a '81 - '87 Chevy pickup. Blazer specific parts are available and the shared pickup parts are everywhere (both new and used)
It came with fuel injection, PS, Power disc front brakes, automatic overdrive trans, so it's basically a modern vehicle wrapped in vintage sheetmetal
Earlier versions had a removeable fiberglass top. With a little work you can make yours removeable and have a "convertible" pickup for open air motoring
These vehicles (73-87 Squarebodies) dress up to look real nice
They are durable as heck. My '87 pickup was a daily driver for 30 years and a quarter million miles.
Cons-
Short wheelbase and high CG can make these a bit squirrely, particularly when trying to go straight down the road or during hard braking
Here's the generic info packet from the GM Heritage center for an '86 Blazer. They didn't have one for an '87, but it would be the same except for the addition of throttle body injection (rather than carburetion) and changing the model designation from "K" to "V".
https://www.gmheritagecenter.com/doc...let-Blazer.pdf
(you could refer to the powertrain information from the '87 pickup. It would be the same: https://www.gmheritagecenter.com/doc...olet-Truck.pdf)
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-02-2017, 11:12 AM   #6
Keith Seymore
Re: 1987 blazer
I have an uncle in Mountain Home Arkansas.
My family is originally from Kennett/Senath MO and Blytheville/Paragould AR. They came to Michigan in the 1950s to work in the "shop" in the auto industry, and to drive the car haulers to the dealerships. Uncle Jim moved back "down home" after he retired.
K
1979-1986
1986 - 2019
Old 06-02-2017, 07:50 PM   #7
Ski-me
Ski-me's Avatar
Re: 1987 blazer
Get some pictures up and more details. We can help you spend your money now!
87' is a good year. First year for fuel injection so that helps a little from carbs. Still separate engine belts but not really too big a deal from a single one.
Some things to check out:
Brakes, Front and rear
Front ball joints
Driveline u-joints
Change the fluids too...they tend to get neglected.
AC, if your lucky it works! If not, takes some money to fix for sure!
Hoses
Minor tune up, plugs, cap, rotor, filters and maybe some new plug wires too.
Tires, make sure the rubber isn't too old (8-10 years) replace.
Welcome to the family! I've got 360k on my 89' and drive it most days. All 3 of my daughters have learned to drive on it.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 06-04-2017, 09:45 AM   #8
65truckowner
Re: 1987 blazer
Thanks for the input. After looking at the title the blazer is a 1988 not 87. We are getting it cleaned up and order a new complete floor covering. I think it is going to be a real good rig. New tires are next on the list.
Old 06-04-2017, 11:07 AM   #9
abig84
abig84's Avatar
Re: 1987 blazer
whats funny about the frame cracking issue is ive owned many rusted out beat k5 blazers and never had a issue. the one truck where the frame actually cracked at the steering gear box was a nicer one that was only used as a daily driver and never seen off road, its more of a stress thing then a rust thing.
just to be paranoid just look at where the 3 bolts attach to the frame on the front driverside of the truck and look for hairline cracks.
other then that these have always been amazing simplistic reliable trucks for me
Old 08-20-2017, 09:13 PM   #10
65truckowner
Re: 1987 blazer
Here is some pictures of the blazer IMG_0473IMG_0471IMG_0468
Old 08-20-2017, 09:18 PM   #11
65truckowner
Re: 1987 blazer
Ok so that did not work lets try againIMG_0471
Old 08-20-2017, 09:19 PM   #12
65truckowner
Re: 1987 blazer
I now not only hate photobucket but also flickr
Old 08-20-2017, 09:28 PM   #13
65truckowner
Re: 1987 blazer
Img_0471
Old 08-20-2017, 09:32 PM   #14
65truckowner
Re: 1987 blazer
Oh well maybe I can figure it out later
Old 08-21-2017, 07:45 PM   #15
frenchy51
frenchy51's Avatar
Re: 1987 blazer
Also check where the rear shocks mount to the frame. My '74 was cracked on the passenger side and BTW-also cracked by steering box. Both not too hard to fix and aftermarket sells braces etc. for both areas. By '88 Chevy probably addressed the issue but good to check it anyway....
My son is also looking for a clean '80's Blazer. I'd love to know what you paid and need pictures when you figure it out-Thanks
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 08-21-2017, 08:45 PM   #16
65truckowner
Re: 1987 blazer
https://www.flickr.com/photos/152291...posted-public/
Old 08-21-2017, 08:46 PM   #17
65truckowner
Re: 1987 blazer
Old 08-22-2017, 02:22 AM   #18
68Timber
I know the pieces fit
68Timber's Avatar
Re: 1987 blazer
That's a really good looking K5.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-22-2017, 09:09 AM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 1987 blazer
Yes looks nice , many are rusted out
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-29-2017, 10:20 PM   #20
Ozark48
Re: 1987 blazer
We were in Calico Rock a few weekends ago. You live in a beautiful area. This is an 85 I just bought in Little Rock
1974 Chevy SWB
1986 Chevy stepside
1987 Chevy Suburban
1988 Chevy R30 Crewcab dually
Ozark48 is offline   Reply With Quote
Old 08-30-2017, 07:31 AM   #21
65truckowner
Re: 1987 blazer
Nice Did you get to do any fishing while in calico rock?
Old 08-30-2017, 05:23 PM   #22
Ozark48
Re: 1987 blazer
No. We were just there for an afternoon. Were planning to visit the area again soon when we can stay longer/have time to look around more
1974 Chevy SWB
1986 Chevy stepside
1987 Chevy Suburban
Old 08-30-2017, 08:01 PM   #23
65truckowner
Re: 1987 blazer
Come to mountain view. There is several things to see here like the caves and the folk center, (If you like that kind of thing) music on the square and a few good places to eat. If you can come in the fall when the leaves change it is really nice here then for sure. Me and the family like to back road as well.
Old 08-30-2017, 09:57 PM   #24
nbrfd007
nbrfd007's Avatar
Re: 1987 blazer
Have good friends up there Glen and Shelia. Did I buy a 66 GMC cab and chassis from you?
nbrfd007 is offline   Reply With Quote
Old 08-31-2017, 07:41 AM   #25
65truckowner
Re: 1987 blazer
They are my cousins and yes I sold a 66 gmc frame and cab a long time ago. Did you do anything with the cab and frame?
