Steering column
Hi folks!
Does this make sense to you? I have installed my column with a new shaft. I use my PS rag joint and coupler as you can see on the pictures. The new shaft runs into the old shaft and do I drill two holes as to tighten it up? And for the upper end, I used the old spring and tightened also. Am I completely lost, or does this process works??? Posted via Mobile Device |
