![]() Join Date: Mar 2000
Can anybody give me some insight why over the last couple of days when on my home pc's I can't log onto this board or My old truck but can log onto any other web site with no problems? I have scanned for viruses and spyware to no avail. E-mail and all other web sites work fine. I keep getting a gateway time out. I have no problems from my work machine. It's only at home that I have this problem. Could my router be causing a problem?
Saskatoon, Saskatchewan Canada |
CCRider
Don't ask me why but my router at home does that all the time...it will block some sites while others work perfect. I have cable and it usally does it if I walk off and leave it on a site all nite. On mine if you unplug the router and plug it back in every thing goes to normal
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Dad's little helper
try this
http://67-72chevytrucks.com/vboard/f...3?s=&forumid=3 your security setting my be too high, select medium or low, I can not get the 67-72chevytrucks main page to come up on my work computer so I mad a link to the message boards. good luck.
too many projects: 61 biscane 67 swb(shaved) 73 Fiat spider 124 Sport 84 Pontiac Grand Prix 86 olds cut. sup. |
67-72 Addict!
I have been having probs also!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
might just be a security setting on the VBulletin boards?? I haven't been having any trouble at work or at home and I have 2 different ISP's
Man Ray, you must have been goin nuts ![]()
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Yup It's PI$$IN' me off. I'll be workin' on it tonite. It's almost as bad as havin' a broken down truck
I just got off of the phone with Shaw and they figured it out. The problem was with the proxy and all it took was to uncheck the automatically detect settings box in the IE tools/ Internet options/connections/lan settings. If anybody else has this problem this is the fix. It's tough not checkin this site out 2 or 3 times a night.........Whew
