Old 05-30-2017, 05:50 PM   #1
Praxiss454
Praxiss454's Avatar
How much POR-15 for Mar-K bed wood?
I ordered a bed wood kit from Mar K and I'm giving it their POR-15 and black paint treatment. Can anyone who has done this confirm how much POR-15 I need to complete it? Short Fleetside 65 GMC.
Second question: do you paint rails with same combo?
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 05-30-2017, 11:51 PM   #2
Praxiss454
Praxiss454's Avatar
Re: How much POR-15 for Mar-K bed wood?
Bump. Was hoping to order some in the next hour or two so it arrives on Thursday along w/ my bed wood. But if no one knows, I will just drive up and buy a couple of quarts and go from there. Would just rather get the right quantity the first time so I'm not rushing in between coats.
Old 05-31-2017, 09:04 AM   #3
Lugnutz65
Lugnutz65's Avatar
I used KBS Coatings instead of POR-15 (essentially the same product). Hard for me to remember how much I used. I think I used a whole quart for a short bed stepside. Use two very thin coats. It seals the wood, but I think the Behr Premium Paint top coat is what really seals it the best.
You should be able to get it covered with 2 quarts of POR-15. I painted my bed strips with the KBS Coatings too, and the cross rails too. I top coated my bed strips with rattle can Rustoleum low gloss black high temp engine paint. Wait until the POR-15 is almost completely dry and then add the spray can top coat. For the bed wood, just let the POR-15 dry completely.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-31-2017, 12:48 PM   #4
Praxiss454
Praxiss454's Avatar
Thanks Lugnutz65, based on your advice I ended up picking up 2 quarts locally. Next I need to go get the top coat paint.
Old 05-31-2017, 04:09 PM   #5
LT1 Burb
LT1 Burb's Avatar
goes a long way, a quart will be plenty
LT1 Burb is offline   Reply With Quote
Old 06-01-2017, 07:45 PM   #6
Praxiss454
Praxiss454's Avatar
For future reference if anyone digs up this thread, 1 quart of POR-15 lasted me about 1.75 coats on my short bed fleetside. The Mar-K website calls for 3 coats. I'm not sure if I'm going to do 3. I probably should since this truck is going to live outdoors.
Old 06-01-2017, 08:49 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
For future reference if anyone digs up this thread, 1 quart of POR-15 lasted me about 1.75 coats on my short bed fleetside. ...
One side or both sides?
Old 06-01-2017, 11:40 PM   #8
Praxiss454
Praxiss454's Avatar
So far I have completed 3 coats, on both top and bottom. I have used just shy of 1.5 qts of POR-15.
Old 06-02-2017, 12:06 PM   #9
jbgroby
jbgroby's Avatar
MAKE SURE you coat the ends and holes very well
jbgroby is offline   Reply With Quote
Old 06-02-2017, 04:32 PM   #10
Praxiss454
Praxiss454's Avatar
A bit off topic from the initial post, but I'm kind of disappointed. I assumed the Mar-K kit, being sold as "pre-drilled", would have all the holes drilled. It only came w/ the frame mounting holes drilled, and I had to drill the remaining holes along the side boards and wheel well myself. I somehow spaced on this fact and did 3 coats of POR-15 before drilling, so now I'm doing 3 more coats of POR-15 just for the drill holes (and splintered areas!).
I've heard top coat adhesion may be an issue, so hopefully sanding all the boards lightly before starting my top coat layers will help with adhesion.
Old 06-02-2017, 04:38 PM   #11
Lugnutz65
Lugnutz65's Avatar
That should be fine.
