Old 05-30-2017, 10:02 PM   #1
ebaby35
Air bag setup
I bought these airbags from ride tech for my 85' clip that's going on my 64 chassis. I installed but haven't put any air in to inflate yet. I talked to ride tech and they said when I inflate the cup should rest on the bottom. Doesn't the bottom need to be bolted to the bottom control arm?
ebaby35 is offline   Reply With Quote
Old 05-31-2017, 12:07 PM   #2
bluex
bluex's Avatar
Re: Air bag setup
No they dont bolt in anywhere. I'm guessing you have the lower arm disconnected from the spindle in the picture? Like they said with the truck on the ground or pressure in the system it will sit in the pocket like it should. They can (and probably will) move around a little but it doesnt hurt anything. Mine were seated in the pocket with no air in them and no weight on the suspension when hooked to the spindle.
You do need to remove that bump/steering stop bracket though to avoid it rubbing on the bag.
bluex is offline   Reply With Quote
Old 06-02-2017, 01:05 PM   #3
JohnJ@RideTech
JohnJ@RideTech's Avatar
Re: Air bag setup
Agreed with bluex. The bag should settle in the cup when you have the truck at rest on the ground. A slight bit of air pressure will keep the bag where it belongs..unless you decide to jump it like Bo and Luke Duke, then there is no guarantee. If you have any further questions, feel free to contact me directly. Ill be more than happy to help you out.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
