Old 10-22-2003, 12:55 PM   #1
Broken_down?
New exahust opinions..
I am going to buy some new exhaust pipes all the way down. I was thinking about putting like 2 1/2 inch diam. or 3 to 3 1/2. With the pipes being that wide, would it make it loud? Cause thats not what I want. I want the ' get outta my way ' sound. not the ' I am stupid my truck is so loud ' sound. Any opinions?
--Broken_down?
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 10-22-2003, 01:01 PM   #2
C10Squared
A nice 2.5 system should be just fine.
'72 Chevy Custom/10 Shortbed
'77 2wd K5 “Halfbaked”
'93 Indy pace truck
‘70 GMC Jimmy
‘76 K5 Blazer
Follow me on instagram @C10squared
C10Squared is offline   Reply With Quote
Old 10-22-2003, 01:01 PM   #3
krue
Designated A-hole!
krue's Avatar
Headers or manifolds? What type mufflers? In my opinion if the pipes are too big it sounds like your in a tunnel. Some of the guys on here have posted sound files of their exhausts, check them out and find what you like.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-22-2003, 01:04 PM   #4
Broken_down?
manifolds. a link to these sounds? I have never seen any.
Old 10-22-2003, 01:05 PM   #5
crazy longhorn
Fabricate till you "puke"
the bigger the pipe dia, the louder it will be. As a rule, a very healthy sb, or mild bb doesnt need more that 2 1/2" pipe on a dual system....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-22-2003, 01:05 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
2.5" is good for a small block up to 400 HP.....
Alot of guys say that 2.5" is too big for a stock motor, and they are right. But, it does sould cool!
One of my friends has 2.5" dual pipes and generic Flowmasters on a stock 305 with log-style manifolds....it actually sounds really good! You would never guess that it is a 305 until you drive it, lol..
I have headers, dual 2.5" pipes, and 40 Series Delta Flow Flowmasters on my truck, dumped before the rear axle. It sounds GOOD, but it gets a bit loud on extended highway trips when i am pulling 3k rpm the whole way....but hey, i'm 19 so loud is good
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-22-2003, 04:31 PM   #7
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I have a stock 327 with a 2bbl carb. (Plan on big cam and 4bbl)
I have the stock manifolds (2.25"outlets), then go to 2.5" all the way out. I'm running a 'true' dual (no x-over) with 50-series Flowmasters. The exhaust kinda resonates a little above idle (kinda annoying when dragging main), but it doesn't get all too much louder at upper RPM than it does at lower (just sounds more raspy). I don't hear it much at all on the highway running 80 turning 3000, prob due to road/wind/old truck vibration noise.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 10-22-2003, 04:49 PM   #8
jugernot
Life, Be In It.....
jugernot's Avatar
3"
I have a 327, hopped up a little. Ceramic headers, delta flow 40 series flowmasters. I am using 3 inch pipe that will exit infront of the rear tires.
jugernot is offline   Reply With Quote
Old 10-22-2003, 04:54 PM   #9
Broken_down?
thats how I plan to do the exhaust also. in front of the rear wheels. looks nice. My truck pic is listed somewhere here, but I am going to in the very near future be looking for some rims again. the ones I got have a bit of rust on them. And maybe a shell to. any custome shells out their that woudl look good and match my trucks.?
rich
Old 10-22-2003, 08:10 PM   #10
dinnut
dinnut's Avatar
both of my trucks dump before the rear tires. kinda strange to find 2 trucks like that imo. i didnt do it. po's did it
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-22-2003, 09:56 PM   #11
matt_field
matt_field's Avatar
ive got 3'' front to rear, straight all the way back with 40s flowmasters on my 383 stroker, WOW it sounds nice
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 10-23-2003, 12:17 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I see it a lot. It's hard as hell to get two pipes out over the axle without hitting the panhard bar on the rear end. Lots of guys just dump it out like that because it's easier. My trucks are always lowered at least 4-6 inches in the back. No pipe room whatsoever then.
Old 10-23-2003, 08:55 AM   #13
miket
miket's Avatar
2.5"....the bigger diameter you go the louder it seems to be.
Check out my site....it has a clips page of exhaust sound files....
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 10-23-2003, 11:31 AM   #14
ts71281
Here's my 468 with 9:1 compression, comp solid lifter cam 236 @.050 duration, .561 lift with 110 lobe separation, pocket ported heads (ovals), port matched intake and a q jet carb, exhaust system with this clip is TRUCK manifolds, 2 1/4 duals running through 24" glasspacks. I have since replaced the manifolds with flowtech headers, full 3 inch pipes into the stage 1 mufflers (dunno who makes them, the exhaust shop carried them) and then reduced to 2 1/2 pipe. I need to get a sound clip of that. Hope this attachment works!!!
Also if you go to
http://exhaustsoundclips.com/gm.html
a BETTER soundclip of my exhaust is available there. They used my truck for the 468 CI V8 soundclip. Like I said, I need to get an updated clip with my headers. I think my truck sounded meaner with the manifolds on but the performance wasn't there like it is now with headers.
Joe Hirdler
ts71281 is offline   Reply With Quote
