Cab/trans fittment.
Hey guys I need some input. I have a 65 swb and wanna do a 350 and 350 turbo trans. I have a small hump cab and would like to do floor shifter. will I have to do and mods other than cut the shifter hole out? Thanks for your time.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Cab/trans fittment.
I have heard on here of people installing 700R4's in their small hump. I fit up a 200R4 in mine with no cutting. A TH350 should not be a problem.
![]() Join Date: Jan 2011
You may need to do a little hammer work on the flange between the firewall and hump.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I guess just get after it and see what happens. Thanks for your time.
Moderator
I remember, I did fit a TH350 first with no issues, then went with the 200R4 - so...
Moderator
Just to ensure apples to apples I used the POL Engine Mounts and Transmission cross-member. https://www.performanceonline.com/19...ION-MOUNT-KIT/
Mine had a TH350 in it when I bought it. it fit fine with no hammer work to the the floor
It's what you learn After you know it all that counts! |
