Old 05-31-2017, 02:12 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Edelbrock Water Pump
Is any one using an Edelbrock Water Pump on their stock with A/C small block 350 C10. They are pricey and advertise as high volume. I know Edelbrock is very good quality stuff but is this Water Pump overkill on my truck. Its a short water pump and I guess thats what I would have on my truck.
http://www.edelbrock.com/automotive/...formance.shtml
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-31-2017, 09:15 PM   #2
Already Gone
Re: Edelbrock Water Pump
Originally Posted by firedemon View Post
i don't have ac but mine moves the needle 1/4 inch up the scale and stays there like someone set a rock on the needle no matter the temp outside and it gets way better heat and faster too .
For 230.00 it oughta work super which from your discription sounds like it does.
Old 05-31-2017, 09:18 PM   #3
clay68c10
clay68c10's Avatar
Check out flow kooler also, they have the high efficiency impellers as well.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-31-2017, 09:50 PM   #4
That's how all my trucks' gauges have read with stock water pump, unless something was wrong.
Old 05-31-2017, 10:24 PM   #5
halfstep
Yes. I use one and cannot recall going much beyond 180 even idling in 90+ humid weather.
If you don't want to pay that price look at Stewart Components they have several offerings and specialize ONLY in COOLING.
Water pump isn't the only factor but this is such a critical and common problem area, I always upgrade here. Timing, tune, mods and gearing have a big influence on heat/cooling also - as I'm sure you know.
I also run a high quality American made Robert Shaw 180 thermostat and a good cap on my stock 3 core radiator. Mechanical fan, no clutch, factory shroud and my engine is well modified.
Stewart Components or Edelbrock are the only ones I'd use. Every thing else is low tolerance, low grade - including virtually all the other aluminum ones along with weiand. There are some vendors out there claiming to have modified stock versions but low quality is low quality.
An improved pitch impeller in a chinese/mexican casting with low build tolerances is just as liable to fail.
Stewart makes several levels including an iron one up to level 3 aluminum.
They like their own, but will tell you that the edelbrock is a very good piece comparable to their level 3.
You may well get by forever with a cheap one but I wouldn't do it.
halfstep is offline   Reply With Quote
Old 06-01-2017, 08:32 AM   #6
What are the specs on these aftermarket pumps? I looked at Stewart pumps and saw no GPM numbers. That's what makes the difference, and to me the most important thing to base a decision on.
