![]() Join Date: Nov 2010
Floor Shifter Boot trim rings
Guys Im building a 1972 4X4 pickup. Is the trim ring the same on the 4sp floor shifter as the transfer case shifter? I have one that is oval. I need one more or someone to tell me which one I have. I don't need a Chrome one. Just
an original Thank you! Last edited by jbgolden; 05-31-2017 at 07:02 PM. Reason: Add a photo |
The Older Generation
Re: Floor Shifter Boot trim rings
23 views and no replies. I will move this to the 4x4 Tech And Off Roading forum to see if you get some help.... LockDoc
20' Daredevil (Ret)
![]() Join Date: May 2003
My K20 has an auto trans, so no help there... However, that looks exactly like the ring on my t-case boot. Measures about 5 1/2" x 7".
![]() Join Date: Apr 2013
Looks like 205 transfer case boot ring
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
I have an original 72 4x4.. my transfer case ring is exactly like the pic you have. The trans shifter ring that I sourced from a 72 is perfectly round, but I have no idea if it was the original one. Mine looks like ( the round ring) all pics i have seen of shifters in these trucks though. Mine was 3 ott I changed it to 4 spd
will have to check mine and let you know
Thanks Guys.....So I have one that is perfectly round and one that is oval like in the picture. Do I have what I need? Looking at the Floor pan it looks like I need two oval's. The round looks two small for a SM465 4sp floor shifter.
![]() Join Date: May 2012
The small round for the transfer, the big oval or square for the transmission. the big one may have 4 or 6 holes. the more rectangular ones have a screw hole at each corner and the long sides for 6. But you will know by the hole sizes of the openings in your hump also.
White K20 |
sorta looks like one for a 65 GTO 4 speed too
I was driving mine this morning and looked down and realized I made a mistake.... The boot is perfectly round but the ring is somewhat oval but different than the transfer case. Ill post pics sorry bout that
It also looks like one for a '70s Duster that YearOne sells... black oval. They also have the rubber boot that goes with it.
It's what I put in my '62 Suburban. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
![]() Join Date: Jul 2015
My k10 with a auto trans has one just like it for the transfer case shifter
#13 |
I checked mine, the one in your pic is for the transfer case, the one for the 4 spd is oval also, just bigger with 6 holes
#14 |
https://issuu.com/truckandcarshop/docs/ts_60-72_web they have the one you need for $11.00 on page 65
Tags |
floor shifter trim ring |
