06-01-2017, 11:41 PM | #1 |
1 1.25" front sway bar bushings??
I have a 1.25" sway bar for the front of My truck and ordered Moog 6476 bushings for it but there is no way I could mound the retainer tight to the mounting surface. Anyone have a part # for Nos ones or aftermarket that actually fit? I really don't want urethane ones if rubber ones are still available.
06-02-2017, 01:37 AM | #2 |
How did I get this OLD!
Re: 1 1.25" front sway bar bushings??
http://67-72chevytrucks.com/vboard/a...1&d=1496381518
I recently installed the same sway bar and Moog urethane bushings. Had to hammer the retainers on with a rubber mallet. Very tight. The retainers came with the 1-1/4" bar though. Are you using the stock bushing retainers? Not sure if there is a difference.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
06-02-2017, 07:09 AM | #3 |
These just showed up yesterday and fit my 1-1/4" bar (from a 1-ton square body truck) perfectly.
https://www.amazon.com/Energy-Suspen...DYFMSHSNGQ8V1W
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
06-02-2017, 08:21 AM | #4 |
Yeah mine are the stock retainers. Do I need aftermarket retainers for these?
06-02-2017, 09:03 AM | #5 |
The factory brackets should work with the bushings you have. It will be, and should be tight.
06-02-2017, 09:29 AM | #6 | |
