Old 06-02-2017, 08:47 AM   #1
Rockin'70Stepside
Rockin'70Stepside's Avatar
Thumbs up Is the strip that goes at the top of the windshield the same on a Blazer and a Truck?
I found a repair kit on Southern Kentucky Classic that has all the pieces that go right above the windshield, but it is tagged for a 69-72 Blazer and I was wondering if the kit would work on a truck. The truck would be a 70-72.
http://sokyclassics.com/product.php?skcid=1003588
Rockin'70Stepside is offline   Reply With Quote
Old 06-02-2017, 09:25 AM   #2
truckster
truckster's Avatar
Re: Is the strip that goes at the top of the windshield the same on a Blazer and a Tr
That kit is to rebuild the windshield header. On the Blazer it's different since the top is removable.
truckster is offline   Reply With Quote
Old 06-02-2017, 09:39 AM   #3
Rockin'70Stepside
Smile Re: Is the strip that goes at the top of the windshield the same on a Blazer and a Tr
Okay, thanks. I kind of thought it was different since the top is removable, but I thought I would go ahead and ask anyways.
Old 06-02-2017, 11:35 AM   #4
raggedjim
raggedjim's Avatar
Are you needing the inside or the outside?
If it is the outside they are the same, see this thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=734763
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 06-02-2017, 04:03 PM   #5
Rockin'70Stepside
The outside.
Old 06-02-2017, 04:34 PM   #6
raggedjim
raggedjim's Avatar
If it is the strip here then they are the same on a blazer and a truck.
Roger
'70 GMC Jimmy 2wd
Old 06-02-2017, 04:47 PM   #7
Rockin'70Stepside
That's what I need. Is there anywhere you know of that sells just that panel?
Old 06-02-2017, 05:33 PM   #8
raggedjim
raggedjim's Avatar
Not that I'm aware of, good luck finding one. You might ask some of the blazer guys who are replacing their windshield frames if that part is good on their old frame. The blazer frames usually rust out on the inside panel and pillars.
Rg
Roger
'70 GMC Jimmy 2wd
