![]() Join Date: Aug 2013
is this normal???
saw this after i got this beast back, should this crease/dent be here?
Re: is this normal???
My 64 K10 does not have that dent...so my guess is it is not normal.
![]() Join Date: Aug 2014
I dont have it either.. Looks like panhard bar may have got against it at some time.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
Post Whore
![]() Join Date: Mar 2013
Nope, ring gear is close to that lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
thanks guys kinda was freaking out. i did find a replacement cover...
I found a Dana 44 cover laying on the ground in a junkyard that had a short pipe welded to the upper area on the cover, with a pipe plug on the end of it--same plug as the fill plug. I'm using it on the front of my K10, to get me around the tie rod when I'm filling it, which is right in the way of the factory fill plug.
It was a manufactured piece, neatly done, not by some hack mechanic. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#8 | |
I bought a 12v transfer pump. Makes filling trans/transfercase/axles easy. funny it said not for gear lube, works fine though. (warm the gear lube first)
1961 chevy K10 my build is------------61K10 build |
