Old 10-22-2003, 04:11 PM   #1
Merl4
Front Crossmember
I have a 1968 C-10 and want to upgrade to front disc brakes. I have read several suggestions about installing a new crossmember (Saddle) from a 1973 to 1985 to accomplish this. I also have several sources with just upgrade kits.
I'm not sure as to which is the most cost effective way to go....leave the stock saddle and upgrade or to install a later crossmember? It seems to be best to go to a salvage yard and just buy the crossmember because of the hardware.
Thank you,
Merl4 is offline   Reply With Quote
Old 10-22-2003, 06:35 PM   #2
crazy longhorn
Fabricate till you "puke"
probably the cheapest route would be to swap in the later crossmember. I prefer the old steel bushings, & have kept the stock crossmember. I have 71-72 lower a arms, with 75 spindles, ball joints,tierod assys & centerlink. The swap can be done either way, & just depends if you have the eng in the truck or out. Its easier to swap the crossmember as a complete unit , if the eng is out of the truck. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-22-2003, 06:42 PM   #3
Merl4
Thanks,
The engine is out......I'm down to the rolling frame. I found a 1985 unit that seems to be in good shape.
I'm able to buy all the brake hardware with it.
Old 10-23-2003, 08:22 PM   #4
BigChevMan
My Thoughts Exactly!
BigChevMan's Avatar
Get the master cylinder and prop valve too if you can. It'll make it a lot easier to use all the components from the same donor.
BigChevMan is offline   Reply With Quote
