Old 06-02-2017, 04:48 PM   #1
bigmac73
bigmac73's Avatar
new rear coils install help
I am installing new trailing arms/ springs and bushings in the rear of my 72 C-10 , in my chevy manual is shows that the end of the coils need to be locked into the tabs on the spring cups.
but the way the cups are orientated to fit in the end of the coil spring i do not see how that is possible and are the cups made different for each side, i ordered 4 and they are all the same?
See pics
the first is the bottom of the coil spring and the other two pics are of the top end of the coil spring , see the tab and the end of the spring.. is this crucial or can i run them as is???
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 06-02-2017, 07:26 PM   #2
trailcarnage
trailcarnage's Avatar
Re: new rear coils install help
I would rotate the cups as far counterclockwise as they will go and call it good
trailcarnage is offline   Reply With Quote
