Old 06-03-2017, 07:14 PM   #1
84lngbed
You pick and pull it yards finds
Post your find here.
Crack free dash bezel, 85 grille and dual headlight bezels.
84lngbed is offline   Reply With Quote
Old 06-04-2017, 12:10 AM   #2
boogie67
boogie67's Avatar
Re: You pick and pull it yards finds
nice find our pick an pull has 3 of these trks but they been picked thru already
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 06-04-2017, 12:24 AM   #3
84lngbed
Got lucky today. It just got in yesterday. Going back tomorrow for the 454 and the th400.
Old 06-04-2017, 03:22 AM   #4
Matt Man
Matt Man's Avatar
a complete headliner and trim. One of many things I have gotten from the junkyard for my 81.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 06-04-2017, 09:16 AM   #5
abig84
abig84's Avatar
coolest/rarest thing i found at pick and pull was a set of flat top knuckles for a dana 44. actually went there looking for them knowing no way i would find a set. got lucky i guess
abig84 is offline   Reply With Quote
Old 06-04-2017, 12:21 PM   #6
84lngbed
Just got done pulling the 454 and the th400 out.
Old 06-04-2017, 12:45 PM   #7
TKCR
TKCR's Avatar
Sweet!!!
Old 06-04-2017, 12:49 PM   #8
TKCR
TKCR's Avatar
This was about a month ago, but I went to get a seat from a local yard, and came back with 2 seats. The FIND was, that there was a stack of grilles in the bed of the truck.
Old 06-04-2017, 01:03 PM   #9
84lngbed
That is a big find.
My uncle might get the bucket seats and the center console from the suburban.
Old 06-04-2017, 01:10 PM   #10
TKCR
TKCR's Avatar
That is a big find.
Forgot about that find. There were already out of vehicle, so I'm not sure exactly what these came out of.
Old 06-05-2017, 10:41 AM   #11
Dead Parrot
Found these two on the same vehicle. Someone had taken the entire front clip off a 1980 except for the radiator core support, the left outer, and inner fender. All were nearly rust free. The outer fender was bent where the yard had set the truck on the supporting tire rims. Wasn't looking for a core support that trip but an almost labor free one was too much to pass on. $30 for the core and either $5 or $15 for the inner fender.
On a different trip, found a cargo tray for my 09 Escape. $5. Dealer price was somewhere on the high side of $300.
Dead Parrot is offline   Reply With Quote
Old 06-06-2017, 01:19 PM   #12
abig84
abig84's Avatar
i would guess early 90s k5 blazer or suburban. thats a k5 blazer center console and the fabric of that seat is the same as my 1990 c1500 silverado bench seat. and for as old and as ugly as my truck is my seats too look that great.
Old 06-06-2017, 06:15 PM   #13
84lngbed
Find a set of almost rust free doors. Only rust on them is on the bottom lips and corner on both doors. Same truck a very good condition bench seat. Wish I had my truck today.
Old 06-06-2017, 07:05 PM   #14
TKCR
TKCR's Avatar
Damn that is a nice seat. How much was the yard asking for it?
Old 06-06-2017, 07:06 PM   #15
TKCR
TKCR's Avatar
Those seatbelts are nice too!!
Old 06-06-2017, 07:32 PM   #16
84lngbed
Like 42 for the seat. I got the door panels. They was in nice shape. 14 each for them
Old 06-07-2017, 11:58 AM   #17
TKCR
TKCR's Avatar
Are you going to go back and get the seat and belts, and use them?
Old 06-07-2017, 12:10 PM   #18
84lngbed
I think my cousin is gonna go get then Friday or tomorrow I think
Old 06-07-2017, 12:25 PM   #19
TKCR
TKCR's Avatar
That's good if you can use them. Just thinking, if you did not use them, it would be almost worth the drive.
Old 06-08-2017, 10:46 PM   #20
superdav
6.0 $1300
superdav is offline   Reply With Quote
Old 06-11-2017, 01:22 AM   #21
Titomars
Titomars's Avatar
Wink Re: You pick and pull it yards finds
My latest score is not Square related exactly. I go out to my Pick N Pull specifically for 73 to 81 square parts. well they were having their 50% off sale so I decided to poke around and see if i could find a few things. after walking the truck line and seeing only stripped squares I decided to walk the GM car line, maybe find a set of Caddy horns or relays etc. as I am walking I run into a 74 Chevelle ........... I just hit the lottery! there are never 70's cars in the yard here. Actually there were 2 gm 70's cars that day the Chevelle and a 79 Vette.
My daily driver is a 75 El Camino. So it's going to be a long day. I am going to strip anything good off this car. My Elkie is a basket case it is basically 3 cars of parts that I reassembled to run. any way got a cherry grille and headlight assemblies both of which look better to me then the 75 design so I snag up those also all the marker lights and bezels, brackets, moldings, relays, seat belts (black), a/c ducting, glove box and door, winshield trim. as i am looking over the rear end of the car (not much that works on an elkie) I jump under it just to eyeball the rear axle. standard 10 bolt in appearance. pop the cover off and behold a beautiful posi diff. with 3.08 gears (elkie has 2.76). Ok my day just got even longer out came the rear axle. the Chevelle also had a TH400. I needed a front pump for a spare 400 I have, so I snagged that too. Since I was in the trans I also yanked out the speedo gears too. I rolled up to the register with a heaping cart. I left the yard only $188.00 lighter
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 06-11-2017, 01:44 AM   #22
TKCR
TKCR's Avatar
That was quite the score all right!!!
Old 06-17-2017, 10:44 AM   #23
84lngbed
Shocked this stayed in the truck that went in in Wednesday.
Old 06-17-2017, 04:04 PM   #24
84lngbed
Also this from last weekend adventures.
Old 06-18-2017, 10:35 AM   #25
TKCR
TKCR's Avatar
A couple of van grilles. The grilles are pretty busted up, but all the trim moldings & bowtie are pretty nice.
