New guy with a 69
Hey guys first post here, figured I better start as I've already been using the forum to research possible front crank seal leaks ��
Lowered a bunch how I like em. I believe it's roughly 4.5-5/6-7 ![]() ![]() ![]() Here's the leak that popped up after a pretty miserable highway drive at 3k rpm lol. Wiped it all up while I was under it to put in a new speedo cable, took it for a drive and looked like a tiny leak from the bottom of the front crank seal. But no more thrown on that inner fender. ![]() Last edited by zachste; 06-03-2017 at 11:54 PM. |
![]() Join Date: Feb 2001
Re: New guy with a 69
Hey zachste
![]() ![]() Luv your ![]() ![]() ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 06-04-2017 at 12:57 PM. |
BlahBlahBlah
This truck has a lot of stuff I normally don't care for. But this one really pulls it off ... I really like it. Welcome to the board.
![]() Join Date: Feb 2002
I like the color.
Welcome from another from Cincinnati, Ohio. Good looking truck. What area of Cincy are you in? I am on the east side in Batavia.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
laying low
![]() Join Date: Mar 2001
Hey that one works. Welcome aboard. Tell us more about it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Feb 2012
You may know this already but when you change the seal on the timing cover for the front of the crankshaft, make sure the harmonic balencer doesn't have a groove in it. If it does, they make a sleeve to "cover" the groove. Sometimes that works, sometimes it doesn't. Nice truck. Worse case you will need new balencer to go with a new seal.
Nice color and stance!
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#9 | ||
I was hoping it was just some loose clamps from this, but they weren't really all that loose. New to v8's, as I'm a long time VW guy. ![]() ![]() ![]() |
After I wiped everything down and took it for a short drive, it looked like some very light seepage in the red circled area. This is supposedly a new crate motor, with everything either new or rebuilt on the truck. I just picked it up about a week ago.
![]() Last edited by zachste; 06-04-2017 at 11:24 AM. |
Welcome to the forum from the great state of Texas! My granddaughter lives east if Cincinnati in Amelia
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
laying low
Well it they reused the harmonic damper it could be the leak. The timing cover seal will wear a groove into the damper and a new one won't properly seal. You can buy a wear ring to slip over the damper to make it all smooth again.
Old VW guy eh? So you are used to oil leaks. I had one too. ![]()
#13 | |
https://www.summitracing.com/parts/f...make/chevrolet I was mostly into early watercooled VW's but still used to oil leaks nonetheless! |
#14 |
does it look like it's leaking oil from a bolt hole in the front passenger side of the block. There's a threaded hole in the lower corner of the block used to tighten a bolt against the fuel pump push rod when replacing pump. Maybe bolt fell out? If you have to put a new bolt in it use a very short bolt as a long one will rub fuel pump rod. Should be a 3/8 bolt. Just an idea
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. ![]() |
#15 | |
#16 |
laying low
One just like that.
Check on that bolt hole too. Some people leave it out and it will leak some though it's not under pressure there.
#17 |
Nice truck, I like the color!
![]() I'm up around Akron .... we should have an all Ohio meet sometime. As far as the leak, don't worry, old trucks are supposed to leak. If it didn't leak, that's when I'd worry. ![]() |
#18 | ||
![]() It's not a terrible leak, but the truck is so clean, and I'm slightly OCD, so I'd like to keep it free from oil being thrown everywhere. But I'd definitely be in for an Ohio meet sometime! Last edited by zachste; 06-04-2017 at 01:48 PM. |
#19 |
laying low
Sure looks like it. Yes the damper will sling oil onto the fuel pump, etc and the fan will spread it out everywhere.
#20 |
Your best bet will be to drop the pan and put a one piece oil pan gasket on it. Simple fix
#21 | |
Posted via Mobile Device |
#22 |
So now the question. Buy a new balancer or just try the sleeve repair? Hmmm
#23 |
[QUOTE=Zone47;7958921]... we should have an all Ohio meet sometime.
[/QUOTE I'm in.
#24 |
JUst pull the balencer and look for a groove on the shaft. That's the easiest way to tell. If there is a groove, that's your leak!!! I'd try the sleeve, it's cheap. I put one on my 66 GTO and it stopped the leak for a month or so. Then the groove appeared in the repair sleeve. Guess the groove was too wide/deep for the sleeve. It's real thin metal and just slips on or lightly tap onto the balencer shaft. It's worth a try if u find a groove. Balencers are $200+/-.
#25 |
Post Whore
![]() Join Date: Feb 2016
If it is the balancer that is leaking and it is grooved another fix is to install a new seal but don't install it as deep in the housing so the lip and grove arel not aligned. Most seals are installed by bottoming the seal in the housing. By not bottoming the seal in the housing many times you can gain 1/8" of offset on the lip and the groove. I done it at least ten times over the years. (Pontiacs are bad for this as the balancer is not on a taper so it always sits in the same place on the crank.) Not every housing will have enough space to do this so measure things up and see.
Oh and nice looking truck. Welcome aboard.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
