Brake drum / wheel quandry
I found a donor '84 C10 and moved the front end over to my '68 for the disc brakes. I also moved the 12 bolt rear axle over to get the 5x5 wheel pattern. Unfortunately when I tried to fit my 15" wheels I found out the wheels won't clear the brake drums.
I know the axle is wider and I anticipated clearance in with the discs up front, but I didn't realize the rear drums would be an issue. Has this been an issue for anyone else? and if so what is the best solution. Thank you. |
Re: Brake drum / wheel quandry
What kind of wheels are u using
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Wheel vintique 62s. 15" 4.5" BS
This is a link to the image because the image is YUGE. https://static.summitracing.com/glob...5812044_xl.jpg |
Wow, that sucks. Do you think that truck was a heavy half or something? Not sure if that was still around in 84. What is the diameter of the new brake drums?
After more inspection - here is where it's hitting. Anyone seen this before? Does anyone care to guess what dumb*** sent his wheels to paint before he slid them on the axle?
I suppose you got the wider drums (2 3/4 inch) with the balance weights that contact some rims.
You might need a wheel spacer to clear them. |
