How heavy is a removable blazer top?
I got a 72 with a single layer top. i have it unbolted and ready to remove. I am waiting until tomorrow morning as I have a bunch of guys showing up to work on the house and I am going to ask them to give me a hand, but it feels kinda heavy. I am thinking three guys on each side and move it back and off the truck and set it on the ground.
Does anybody know how much it weighs? |
![]() Join Date: Jan 2001
Re: How heavy is a removable blazer top?
BobbyK (board member) weighed his at around 240 or so. I've taken mine off by myself, but it helps to have another pair of hands to steady it.
So myself and three other guys should be no problem?
it's not nearly as heavy as it looks. 2 or 3 people can easily do it.
Stalker Nate
Pretty light, I took mine off daily by myself when I daily drove my '72. You get used to it lol Couple hundred pounds sounds about right.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
![]() Join Date: Jan 2007
2 people is way easier than trying to do it yourself unless you have a hoist/lift to assist.
I balance the load on my back and walk it off the back. I have my sons help me with balancing it.
Wasn't that bad to remove but there is no way I could do that with just the wife helping.
They are heavy. To me, they are just awkward to handle because of majority of area/weight hanging over the front & not straight above you when pick up by rails.
Easiest with at least 3 people - one on each side under side windows, slide it back a little & put a third person at the front.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
when i had my 84 two people could do it if they had some muscles. i had a broken down 80s s10 blazer in my driveway for a while and i used to back up close to it and slide it off by myself right onto the roof rack of that thing worked great. so all you need is a s10 blazer to help out
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Ya...my single walled top weighs 240lb's.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Is that lift system your design?
#13 |
![]() Join Date: Jun 2002
Can 2 guys do it? Sure. Should they? Probably not. I used 3 guys one time, then I started using 4, but then again, we're old farts!
Good luck, and it's not worth getting anyone hurt over. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#14 |
I'd call it a "universal" design.
I built it with the design in my head. Improving on previous lift's I had made in the past. I chose the materials + figured out the dimensions. Somebody, somewhere, has made something similar before me... I'm sure. Here is a link to the pic's I took while building it. https://public.fotki.com/blazbk/blaz...g-the-roof-to/ And here is a video of it in operation. https://youtu.be/4X-flPMbAxE
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-23-2018 at 08:48 PM. |
#15 |
Here’s how the pros do it !
#16 |
Just took mine off this passed week.
I've done it twice with 2 people, and once with 3. I always place blocks under it before lifting it off. Then one person on each side. The issue I have is that we always pick it up too far forward and the hatch tries to roll it over. The next issue is that mine is 4 wd with slightly larger tires so you are lifting right in the middle of your chest where you have less strength. We aren't body builders and with some minor stretching and whining, we get it done relatively easily. Still wish I had one of the contraptions posted above.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
