Old 06-04-2017, 08:57 PM   #1
arocars
Help! Broken bench seat spring
Hi. I am restoring and recovering my 1968 bench seat. Everything is good except that one of the funky looking "C" shaped springs is broken. I think if I weld it, it's just going to break at the weld. Does anyone have any ideas for replacing this spring?
arocars is offline   Reply With Quote
Old 06-05-2017, 06:45 AM   #2
Zeroman
Zeroman's Avatar
Re: Help! Broken bench seat spring
I used the replacement side springs for the earlier seat. Got them from LMC.
Side note - probably the only thing I would buy from LMC.....
Anyway, they are not the same. I cut off both ends of the spring, and spring is held onto the top with only one metal "keeper", not two as original.
It is working so far without any problems. It is definitely working better than a broken one.
Zeroman is offline   Reply With Quote
Old 06-05-2017, 11:18 AM   #3
arocars
Thanks Z-man. I looked through the catalog a couple of times and totally missed it. But thanks to you, I found something that might work. Heck, for $4, how far wrong can I go? Thanks again.
Old 06-05-2017, 05:05 PM   #4
Camaroguy
Camaroguy's Avatar
I only had one broken spring when I rebuilt my seat. Took a piece of welding rod and bent it like the other side and tacked it into place. No problems.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
