Old 06-05-2017, 10:40 AM   #1
Hart_Rod
Hart_Rod's Avatar
C10 Truck Trailing Arm Anti Squat Bracket Kit
Who else makes these beside POL and Hotchkiss? I'm trying to correct an pinion angle problem that is causing me a vibration and am checking out my options. TIA
https://www.performanceonline.com/19...t-Bracket-Kit/
Hart_Rod is offline   Reply With Quote
Old 06-05-2017, 12:19 PM   #2
tinydb84
tinydb84's Avatar
Re: C10 Truck Trailing Arm Anti Squat Bracket Kit
I've seen a lot of people flip the bracket. I think Super73 made his own. Any reason you don't shim the rear or weld on new perches?
David
Instagram: myfabguy
Old 06-05-2017, 12:51 PM   #3
Hart_Rod
Hart_Rod's Avatar
I'm using PB dropped arms. The truck is built and running and I was trying to keep it simple. I may just flip the bracket.
Old 06-05-2017, 09:44 PM   #4
68c10airstream
68c10airstream's Avatar
I've thought for a long time if i needed to do this i would weld additional metal plates predrilled and weld them to the top, because i hate to drill out rivets. My grandpa worked on the railroad and fixed steam locomotives and said" nothing beats a rivet, fills misaligned holes, can't unthread, vibration resistant etc. if it holds a skyscraper together it's good enough for me".
68c10airstream is offline   Reply With Quote
Old 06-06-2017, 06:48 AM   #5
PGSigns
PGSigns's Avatar
I use shims to set the angle. Quick and easy. These are from speedway but others also carry them. http://www.speedwaymotors.com/Rear-A...up,294450.html
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-06-2017, 08:11 AM   #6
Hart_Rod
Hart_Rod's Avatar
Certainly one way to do it, . And agree on the rivits, .
Jimmy
I have some shims, I'm just not sure that 4 degrees is going to be good enough to take care of the problem. I'm doing a 2 piece driveshaft with a slip yoke in the center and my transmission can't go any higher. I'll try the shims with the new drive shaft and see how that goes.
Old 06-08-2017, 08:57 AM   #7
Hart_Rod
Hart_Rod's Avatar
Does anyone see a problem with going with a 6 degree shim?
Old 06-08-2017, 11:26 AM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
FWIW, I'm running a 6* shim on my '69 with Hotchkis 6" rear drop springs & 1.5" block. No issues so far.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
