Old 06-05-2017, 11:55 AM   #1
made2drag
made2drag's Avatar
64 made2drag c10
made2drag is offline   Reply With Quote
Old 06-05-2017, 12:04 PM   #2
made2drag
made2drag's Avatar
Re: 64 made2drag c10
I've been asking car guys in the area if anyone knew of a 64-66 c10 really cheap. Ran into a guy who has one and knew of a parts truck. He said it was a 3/4 ton and thought it would be going to scrap soon due to nothing really left on it to part out. Come to find out, I knew the owner from swap meets and car cruises and he was excited that he finally found someone to show it some appreciation. I basically bought the door and got the rest for free. LOL. He says no hurry to pick it up and haul it home, so all I have are pics at the moment. He said it was a 64...the vin in the door opening above the door hatch is in the 64 only spot. I was so excited I didn't even look or take a pic of the vin.
Old 06-05-2017, 12:07 PM   #3
made2drag
made2drag's Avatar
Needless to say, I will be accruing parts over the next couple of years in order to put this one together. Plans will be a 5 lug disc conversion with a 5/6 drop and shortening the frame and most likely making it a rough driver. 350/3 speed or might do an auto. Wont be anytime soon though. Check back in a few years! LOL
Old 06-05-2017, 04:38 PM   #4
forestb
forestb's Avatar
With tires in that shape it is definitely made to drag. Sorry I couldn't resist.
forestb is offline   Reply With Quote
Old 06-06-2017, 12:16 AM   #5
Captainfab
60-66 Nut
That is definitely a project but I have seen people start with worse.
Old 06-06-2017, 09:42 AM   #6
made2drag
made2drag's Avatar
LOL, I like that! When I pick it up, the dude says he can use his forklift to place it on the car trailer! When it's home, we will have to tie it to a tree and yank it off. LOL
Old 06-06-2017, 09:50 AM   #7
made2drag
made2drag's Avatar
Yeah, I thought my 56 was bad. At least it came with parts.
The reason I liked this truck is:
No one wanted it because it was long bed and 8 lug. So I got it really cheap.
I'm going to do a ball joint out 5 lug disc conversion anyway.
Its ready for wire brushing and painting the frame.
I can do a new bumper and grille and new fleet bedsides and find stock hood and clip pieces.
The cab seems to be in really good shape for being 53 years old. 2 cab corners and a rocker and maybe some floor patches...
If it were a stock stepper with a straight 6 and 6 lug, it would be changed anyway. Less work, really. Im happy!
Old 06-07-2017, 01:04 AM   #8
Captainfab
60-66 Nut
I don't think you can press in a lower balljoint that will accept a 1/2 ton dropped spindle. The C20 lower control arms as well as the entire front crossmember are different than the C10 components. I have never tried a C10 balljoint in a C20 lower control arm, but I am pretty sure the hole in the control arm is too big.
Old 06-07-2017, 09:10 AM   #9
made2drag
made2drag's Avatar
Ok cool,thanks! I have 2 pairs of 73-87 upper and lower arms. I didn't know that. Im so glad I kept those. I'm pretty sure the control arm bushings are rotted out on the truck, so looks like I'll be replacing almost everything.
Old 06-07-2017, 09:13 AM   #10
made2drag
made2drag's Avatar
I cant wait to start on this truck... seriously don't see it happening til after I get my 69 drivable. I really just need a big chunk of time to put it together.
Old 06-08-2017, 01:15 AM   #11
Captainfab
60-66 Nut
On the '63-'66 C20/30 trucks you can not simply change the control arms, you have to change the crossmember as well. This is due to the C20/30 lower control arm shafts are flat and not round. There are no saddles on the crossmember to accept a round control arm shaft.
Old 06-08-2017, 09:21 AM   #12
made2drag
made2drag's Avatar
ok, thanks. Didn't know that either. Luckily I have an entire 73-87 loaded crossmember. LOL, no joke...
Old 06-08-2017, 09:23 AM   #13
made2drag
made2drag's Avatar
And seeing your post.... it just hit me its a c20... any other differences between the c20 and c10 once the crossmember is changed and the rear end and springs are changed?
Old 06-08-2017, 09:28 AM   #14
made2drag
made2drag's Avatar
Also, can anyone tell from the pics if that is a fleetside bed front panel? The poison ivy kept me from walking around the truck and the dude had some many cars and trucks that distracted me away after I shook hands on the truck, knowing I was 100% buying it. The cab and frame looked excellent from where I stood.
Old 06-09-2017, 12:00 AM   #15
Captainfab
60-66 Nut
Aside from the slightly thicker frame, the rear cab mounts are different and there are braces from the trailing arm crossmember over to the frame.
It's hard to tell in the pics but that front bed panel does appear to be for a fleetside. However the bed cross sills that are on the frame are for a stepside.
Old 06-09-2017, 09:05 AM   #16
made2drag
made2drag's Avatar
WOW, thanks!!! I love learning about trucks I've never had before. Cant wait to get it home!
Old 06-09-2017, 04:42 PM   #17
shp4man
shp4man's Avatar
I hope the PO gave you the key to the gas cap.......
Just kidding!
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 06-10-2017, 12:14 PM   #18
68Timber
I know the pieces fit
68Timber's Avatar
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-12-2017, 09:39 AM   #19
made2drag
made2drag's Avatar
Just kidding!
I saw that! Come to think about it, I didn't ask about ignition key either! I know those as easily changed but I was so excited I could buy it and it is only 5 miles away and happens to be a good friend of my friend who is gonna tow it for me.
Plus, just the front bed panel would cost me more than I bought everything for. Definitely getting fleet bedsides!
