06-05-2017, 01:33 PM | #1 |
1960 Apache for sale (most of one anyway)
Here's a great project or parts someone might want to consider. If you have dreamed of finding a cab with TRUE ZERO rust in the floors, rockers, etc, then this one is it - BUT a tree fell near it and a limb from the tree mashed a couple spots on the roof - so you'd have to fix that instead. It has a few small holes in the cab corners, but ZERO holes ANYWHERE in the floor boards, or around the rockers. Has a 3 speed shifter hole in the transmission cover, and does have a series of small holes beginning in the inner roof over the visors inside, but otherwise is a beautiful cab to work on vs so many that require hours and hours of labor fixing rockers and floors. The roof damage is fairly significant, but that is what the extra cab is for - I have a second cab that is more typically rotted in the floors you can buy for 200.00 to cut any metal pieces or roof parts from if you want to pick up both vs stud gunning the roof metal and working it back into shape.
Price for the single 1960 Cab w/ clear Alabama registration (no titles in Alabama before 1985) is 700.00 or take both cabs for 900.00 If you want the super nice short frame under the cab, add 200.00 more - its perfect and straight in every way - most beautiful 1960 frame I've personally ever seen. If you want the also perfect and 100% rust free inner fenders they are 100.00 each or add the also 100% rot free core support and battery tray for another 150.00 The hood is here too - has some rot and cheesecloth under where the emblem mounts, and some toothpick sized holes in the front outer corners, etc and has some paper thin bondo covering light dents on the drivers front edge, but a very straight, very restorable hard to find hood. Hood is 250.00 vs 500 up for a more perfect solid one. The cab is full of spare parts of all kinds - glovebox door, cowl extensions, miscellaneous engine pullys and parts, etc. A ton of stuff in there. So this ad is for a cab buyer to choose his options - once the cab buyer is found and his decision whether to take or leave additional parts above is made, then whatever he did not take will be for sale individually - NOT until the cab buyer decides first though - reason being, it may well be that a person buying this cab will want the frame, front end, hood etc, with the intent of building it vs only acquiring a replacement cab for an existing project. SHIPPING: truck is located in Eva AL 35621 and can be delivered to you in any state of the union - Randy Kroth lives here and he hauls stuff like this for a living. He charges an average of .75 cents per loaded mile (one way) but also makes one-off deals based on pre-existing trips to or through your state - call him at 256-200-2824 to inquire. He is leaving for San Diego tomorrow and headed to Colorado and all across the West. Questions about the cab and parts : Text or Call me at 256 486 1988 Thanks, Steve
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
06-05-2017, 01:53 PM | #2 |
Re: 1960 Apache for sale (most of one anyway)
Here is the link to all 86 pictures of every conceivable angle on this cab and its related parts plus parts I forgot to mention above.
https://1960cabandparts.shutterfly.com/ Click "pictures and videos" at the top right of the home page to scroll through everything....
06-06-2017, 10:16 AM | #3 |
Forgot to discuss the doors - Doors are included in the 700 cab price; both are super solid but both have at least a little rust through somewhere - bottoms are good on both - call for details
