Old 06-05-2017, 03:10 PM   #1
davepl
davepl's Avatar
M20 vs M21
The M20 is the "wide ratio" and the M21 is the "close ratio" - but which is better for street driving? I'm not interested in drag racing this one, so just curious as to which set of ratios would make for a better cruiser.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-05-2017, 04:32 PM   #2
gvnick
Re: M20 vs M21
The M20 would be the better choice. It has a lower 1st gear, the same close ratio spread 1-2-3 (fun), and just a wide gap from 3-4.
69 GMC shortbed
Carbed LM4 - Manual VB TH350 - Gear Vendors OD
gvnick is offline   Reply With Quote
Old 06-05-2017, 04:34 PM   #3
leftybass209
leftybass209's Avatar
Re: M20 vs M21
It depends where your engine makes most of its power at what RPM. Regardless of street or racing purposes, you'd still want to shift inside your engines optimal power band.
leftybass209 is offline   Reply With Quote
Old 06-05-2017, 04:38 PM   #4
Grumpy old man
Grumpy old man's Avatar
Re: M20 vs M21
https://www.hotrodhotline.com/magica...d#.WTXAgdwpDIU
Grumpy old man is offline   Reply With Quote
Old 06-05-2017, 05:08 PM   #5
DANTIP
DANTIP's Avatar
Re: M20 vs M21
The wide ratio was typically used on muscle cars with rear gears around 3.55. The close ratio (M21 and M22) were typically used on muscle cars with 3.73 and numerically higher gears. The M22 was also used in heavy-duty/big CID muscle cars due to the tougher gear-set.
Good Luck!
DANTIP is offline   Reply With Quote
Old 06-05-2017, 08:34 PM   #6
Mike C
Mike C's Avatar
Re: M20 vs M21
You are talking car 4 speeds? The SM465 is M20 in the trucks as the wide ratio 4 speed.
If we are talking car Muncie 4 speeds you will be MUCH happier with the 2.52/2.56 first gear of the wide ratio trans over the 2.20 first of the close ratio trans.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-06-2017, 06:28 AM   #7
Re: M20 vs M21
The M20 was designed to be better for regular driving. They were all built for performance, but as the number goes up so does the level of performance.
