Old 06-05-2017, 11:16 PM   #1
Bttlfed98gt
Suburban cluster
Does anyone know the pinot for the 90/91 cluster swap into a 88?
Bttlfed98gt is offline   Reply With Quote
Old 06-19-2017, 09:23 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Suburban cluster
If I got this right 1988 trucks cluster 1/2, 3/4 Ton, 1992 1 ton Suburban cluster same speedo next gen.
If your 87,88,89,90,91 1/2, 3/4, 1Ton Suburban cluster same 81-87 truck 1/2, 3/4 Ton a lot same few key parts changes.
Hope this answer your question: Direct fit would be under lined. with a un-touched cluster you will have look closely. If you want a direct factory replacement.( of the same OPTION on your Suburban.)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-20-2017, 08:38 AM   #3
DBLSPRT68
DBLSPRT68's Avatar
The 90 cluster is electronic, even though it looks the same. 80-87 C/K trucks and 80-90 Suburban clusters are the same an will swap around. 73-80 had differences, and you must be careful with those. Only difference is the Suburbans had trip counters in the later speedometers.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 06-20-2017, 01:48 PM   #4
abig84
abig84's Avatar
i remember tearing apart a 89 1ton years ago and it had a goofy sensor in the back of the speedometer, kinda looked like a electric eye that twisted into the back of the gauge, and i was told it was a VSS. ever hear of anything like that?
i think its the one i have in my 86 now, its got the trip but its broken
abig84 is offline   Reply With Quote
Old 06-20-2017, 02:03 PM   #5
ray_mcavoy
Yes, that would be a VSS (Vehicle Speed Sensor). I believe they were first used in these trucks starting around 1983 when equipped with cruise control. I think they were also used for the engine control system on 87+ trucks with fuel injection.
When the electronic speedometers were introduced, the VSS was moved down to the transmission where it took the place of the speedometer cable drive.
ray_mcavoy is offline   Reply With Quote
Old 06-21-2017, 01:40 PM   #6
abig84
abig84's Avatar
interesting. thanks, i knew i wasnt crazy
